What are you guys doing for crank case evac / PVC?
Car: 1991 Corvette
Engine: Bottle fed L98
Transmission: ZF 6 speed
Axle/Gears: D44 IRS/3.92
I have a breather in each valve cover of my 383. The breathers are misting oil during extended WOT. It's especially bad if I use the nitrous system.
I'm thinking of installing a catch can, but I'm not sure that is going to solve the crank case pressurization issue. Anyone here had luck venting to the exhaust on a car with mufflers?
Anyone here figure out a vacuum pump solution that is daily driver friendly and won't put me in the poor house?
Other suggestions?
Other suggestions?
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: What are you guys doing for crank case evac / PVC?
do you have a pvc in there now or just 2 hoses i would run a pvc in there and you could run a catch can too thats what i'm gonna do for my motor
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
You aren't boosted, so why not run a normal pvc? I'm using 2 breathers too and will get a little oil on the drivers valve cover. If it gets worse, I'll probably do the catch can method.
Car: 1986 iroc
the motor i run now is supercharged with only 6psi and i still run a pcv thats why your getting mist always run a pcv unless its all out race motor
ambainb
Apr 25, 2016 09:21 PM
