pro charged LO5
Old Jun 23, 2010 | 02:54 AM
shanep1991's Avatar
pro charged LO5
i have a stock LO5 in my garage just sitting there and i bought a 1985 camaro with a stock 305 aside from headers,intake and carb, i believe it has 416 heads on it so i would use those on this build
what does a properly tuned pro charged 305 run at the strip? it would have forged pistons and rev to about 6500 with a balanced rotating assembly, idk what pistons/cam/intake or anything to get so any suggestions would help, i guess my main question is, is it worth building this and what are the parts i should use to build this? the LO5 is not a roller, idk if it has the provisions for a roller though, its out of a 1989 truck
what pistons should i get and what compression ratio should i use with a pro charger?
i also dont know what pro charger to use so any suggestions on that would help too, the engine is carbed also
Old Jun 24, 2010 | 02:27 PM
83 Crossfire TA's Avatar
Re: pro charged LO5
Man, do some reading around here and then narrow down your questions, most of what you ask has been covered in other threads and you're asking about just about every aspect of the combination, change one or 2 and you'll get a completely different answer for the rest, it's next to impossible to answer realistically.
L05 truck block- should be a "roller block" casting but won't have any of the roller parts in it.
Falcon50
Aug 22, 2020 03:26 PM
apie2546
Oct 16, 2016 02:24 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
RS Reaper
Sep 27, 2015 07:04 PM
