crossfire nitrous set up?
Car: 83 camaro z28, 92 xj
Engine: 305 Crossfire (lu5)
Axle/Gears: richmond gear 3.73:1
does anyone know where i could buy a nitrous set up for a crossfire? or if its even possible?
Re: crossfire nitrous set up?
There used to be a N20 system available but discontinued. But it can be made from a parts list. That list is somewhere on this site. All you need is 2 foggers within the air cleaner I recall. From bottom up with a Y block or fitting. NOS systems sells a generic EFI system 7006. you would need another nozzle and a couple more 4AN hoses and the Y block/fitting. Most likely need a stronger fuel pump as well.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
[Sold] Accel 30# injectors
hydrolic144
Aug 29, 2015 04:14 PM
mustangdmurder
Aug 21, 2015 07:17 PM
3rdgenparts
Aug 6, 2015 09:03 AM
