Choice of two engines help/opinion
Old Oct 1, 2010 | 11:38 AM
spkx714's Avatar
Car: 1986 IROC Z
Engine: 383/D1SC
Transmission: TH 700R4 or TH 7004R
Axle/Gears: Moser 9" 370:1
I have a D1SC intercooled SC, AFR 195, 75cc combustion chamber, Walbro 225, FMU, Magnafuel boost referrenced regulator, 230/236 113 cam, BS3 computer. (That maybe bad for me 'cause there is no help.) in a 1986 IROC Z that will be mostly driven on the street, maybe to the track once or twice. There are two engine choices for the same money
Block 1 is a 383 built for a SC.
Block: GM 1 pc roller cam block, thermally cleaned and Stainless Steel Shot. Inspected by MPI process. Decked, bored, honed with torque-plates and pressure washed. Durabond cam bearings and pioneer brass freeze plugs installed. 4-bolt main caps with ARP main studs.
Block is O-ringed.
Crank: Eagle 4340 Forged Steel, internal balanced front and rear
Rods: Eagle forged 4340 H-beam, 5.7” length, floating pin
Pistons: SRP forged blower pistons
Rings: Mahle Plasma rings
Bearings: ACL H-series Main and Rod Bearings
Core Plugs: Brass Pioneer core plugs
Block 2 is a 396
Block: GM 1 pc roller cam block, thermally cleaned and Stainless Steel Shot. Inspected by MPI process. Decked, bored, honed with torque-plates and pressure washed. Durabond cam bearings and pioneer brass freeze plugs installed. 4-bolt main caps and ARP main studs.
Crank: Eagle 4340 forged steel, internal balanced front and rear
Rods: Eagle forged 4340 H-beam, 6” length, floating pin.
Pistons: Mahle forged piston with anti-friction coating
Main Studs: ARP performance main studs
Any thoughts?
Thanks,
Steve King
Old Oct 3, 2010 | 08:35 AM
spkx714's Avatar
Car: 1986 IROC Z
Engine: 383/D1SC
Re: Choice of two engines help/opinion
Nodody thinks one is better?
Old Oct 3, 2010 | 09:12 AM
DIGGLER's Avatar
383. 396 with 6" rod probably has a less desireable ring placement.
Old Oct 3, 2010 | 09:23 AM
spkx714's Avatar
Car: 1986 IROC Z
Engine: 383/D1SC
Thanks.
camaro71633
Sep 1, 2015 10:24 AM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
