383 Pinging noise after cam/lifters/valves/plugs/supercharger replaced *VIDEOS*
Old Nov 3, 2010 | 07:53 PM
neeb_usmc's Avatar
Car: 1985 Trans AM
Engine: 350 ATK Performance
Axle/Gears: Eaton 3.73
Okay guys, heres the deal. Before anyone asks I have no history on my car, and realize this was a mistake to buy a built car without it. I tried EVERYTHING to get info, but nothing. I bought this car and right away noticed it has a huge lack of power for having a 383 stroker, and a paxton supercharger. Well I took it to a performance shop, and one of the lifters was so bad you could push it in on cylinder 8. Took it all apart and the cam was messed up too. So I got the whole nine yards replaced as you can see in the title. While the supercharger was offwe noticed it was hard to turn the pulley( approx. 65 pounds) and I personally called Craig at Paradise wheels and he said to send it in. Someone tried to rebuild it and put to big of springs, so I upgraded to a SN2000 from a SN90. Everything was installed and I got it on the Dyno and there was a pinging noise, so I got some higher grade gas, and still there. The mech was stumped, so I wasnt happy after spending over $3500. I figured if this is your profession you should know what you did b/c it wasnt making this noise prior. I took the valves off myself and the cylinder(8) has a really noticably loose valve, and it was the same one that was bad before. SO WHAT DO YOU GUYS THINK??
I have a new appt at a Hot Rod shop on thursday, and am having her towed there, but Im just looking for input. THANKS IN ADVANCE, I WILL UPDATE THIS THREAD THROUGHOUT THE PROCESS OF REPAIRS
Here is a video of the car on, and running with the pinging
HERES THE LOOSE VALVE
Old Nov 3, 2010 | 08:35 PM
neeb_usmc's Avatar
Car: 1985 Trans AM
Re: 383 Pinging noise after cam/lifters/valves/plugs/supercharger replaced *VIDEOS*
no one?
Old Nov 3, 2010 | 08:55 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
hard to say without hands on... did you try readjusting the valves?
Id assume the guy checked for bent pushrods,valves,etc..
pulled out stud? screw in studs,? etc...
Old Nov 3, 2010 | 09:09 PM
neeb_usmc's Avatar
Car: 1985 Trans AM
Well in the second video you can see that one being really loose, there are some that are so tight that you cant move them, and some that slightly move. So the mech definatly didnt tighten them all the same. I would assume he did check too, but it definatly wasnt making this noise prior to the new stuff, it was just slow as hell
Old Nov 3, 2010 | 09:50 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
screw in rocker are studs or press in? what type of heads on the engine?
Old Nov 4, 2010 | 02:12 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
You need to check/adjust the valves when the piston is at TDC.
and all the thing TPI383 wrote needs to be checked.
Old Nov 4, 2010 | 07:22 AM
zz17iroc's Avatar
Car: 91' Z28, 92' Z28
Engine: 383, L98 stock
Transmission: Built 700R4, Stock 700R4
Axle/Gears: 12 Bolt 3.73, 10 Bolt 3.23
You need to re-adjust your valves. It looks like the intake valve is completely closed, so all that tells me is your mechanic only did a cold adjustment while the motor was on the stand. Some times you get a lazy lifter but very rare. If all valve train components are new, you more than likely don't need to do what 383TPI has suggested. But it still won't hurt!! Now that you have the valve cover off place a trimmed piece of card board inside the head so you don't get oil everywhere and start the car up, make sure all vacuum ports are plugged off and start adjusting your valves beginning with the loose one first to see if the noise goes away. If so then continue with your adjustment while the car is still running by back off the nut until you hear it start tapping then tighten it back up just enough for the tapping to stop and then tighten an additional 1/4 to 1/2 turn. That should fix you up.
Old Nov 4, 2010 | 07:33 AM
neeb_usmc's Avatar
Car: 1985 Trans AM
I will look at it at about 3pm. Thanks
neeb_usmc's Avatar
Car: 1985 Trans AM
No clue on anything on it
Old Nov 4, 2010 | 07:35 AM
neeb_usmc's Avatar
Car: 1985 Trans AM
So all my replys are pretty much telling me to check the valves and tighten them. I will get on it at 3pm
Old Nov 4, 2010 | 02:51 PM
neeb_usmc's Avatar
Car: 1985 Trans AM
decided I dont know if Im up for this. On a scale of one to ten how complex would you say it is to adjust the valves w/o having done it before?
Old Nov 4, 2010 | 03:01 PM
zz17iroc's Avatar
Sure you can do it, don't cop out on us now. How do you think majority of the mechanics out here got started. They had to start somewhere. Just take your time and start off like I stated this morning. You do fine!!!!!
Old Nov 4, 2010 | 03:07 PM
scamaro355's Avatar
Car: 92 rs
Engine: 355 stealth ram, dart heads, S480
Transmission: 4L80E
well if you over tighten them you'll bend pushrods and if you dont get them tight enough it'll run like crap.. if it runs.. do a search on adjusting the valves.. its pretty straight forward.. good luck....
Old Nov 4, 2010 | 03:13 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Its very easy....
http://www.youtube.com/watch?v=89o5rLpbCgI
Old Nov 4, 2010 | 03:27 PM
neeb_usmc's Avatar
Car: 1985 Trans AM
deal.. im on my way to autozone. need to adjust my plugs too. should i strip my motor down till it looks like that in the video?
Old Nov 4, 2010 | 03:34 PM
No, just bring the engine to top dead center, and start on number one. After you finish number one, then continue on with the rest of them in firing order. Since you can't see the lifter because the intake manifold is on, keep an eye on the intake rocker arm for the very next set (in this case it would be number eight), as it should be higher than the exhaust rocker's number eight. Rotate the engine until the intake rocker number eight meets the exhaust rocker number eight, then proceed adjsuting lash. Keep doing this until all rocker arms are adjusted, but remember, do this in the firing order starting with number one at top dead center. Firing order is 1-8-4-3-6-5-7-2....
If your still confused, ask questions first....
Old Nov 4, 2010 | 04:32 PM
neeb_usmc's Avatar
Car: 1985 Trans AM
this is just a lot of info im reading and i am worried i just wish i had someone here to talk me through it. I have a lot invested in this car and am nervous as hell i am going to damage more stuff
Old Nov 4, 2010 | 05:28 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
I would feel the same way if I was in your situation. People are telling you how to set the lifters when in fact you never said if it is a mechanical or hydraulic cam. The methods for adjusting the valves is very different so yeah you could mess up more stuff.
For the cost of the valve adjust and how much you already spent I would just have someone with the knowledge do it.
Old Nov 4, 2010 | 06:47 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
flat tappet or roller. Same process. now if its SOLID its diff.
Im gonna guess its hydraulic rollers.
to many diff. ways to do it. all are easy.........
That being said all the above are right also.. Here are a few listed out for future readers. Ive used these ways with good results.
get #1 at TDC then......
I hold the pushrod between two fingers lifting the pushrod up and down while slowly tightening. When you reach the point where there is no up and down movement you will be at ‘0’ lash. Then I go 3/4 turn. DO THIS TO ALL OF THEM!!! I do all one side and then all the other.
Turn over by hand 360* adjust the loose rockers again. the same way as above. (should be 4 loose one) put valve covers on and done. You should be good to go
The problem with spinning the pushrod and attempting to get the correct ‘feel’ is that you can and will still be able to spin the pushrod even if you bottom out the lifter. This can cause you to over tighten the adjustment and can lead to bent and / or broken pushrods and valves.
If you want to be quick about it...
bring the number 1 piston at Top Dead Center (TDC) on compression stroke.
Adjust intake valve on #2 and #7;exhaust valves #4 and #8.
Rotate crankshaft 180 degrees clockwise and adjust intake valve on #1 and #8;
exhaust valves #3 and #6.
Rotate crankshaft 180 degrees again (TDC) and adjust intake valves #3 and #4;
exhaust valves #5 and #7.
Rotate crankshaft again 180 degrees and adjust intake valves #5 and #6;
exhaust valves #1 and #2.
I found this method doing a search on this site.
I have used this method on occasion. The first method is more acurate; however this works well also.
Valve Adjustment The Quick Way:
With the engine OFF and spark plugs removed so that you can rotate the engine with less effort.
1. Get #1 piston to compression TDC, Cam gear at 12 o'clock crank gear at 12 o'clock.
2. Adjust the intake valves on cylinders 1, 2, 5, & 7 by loosening the rocker nut until play is in the pushrod then just take the up and down play in the pushrod and tighten the rocker nut 90 degrees
3. Adjust the exhaust valves on 1, 3, 4, & 8 in the same manner.
4. Rotate crank 360 degrees to get cylinder #6 to compression TDC, Cam gear at 6 o'clock and crank gear at 12 o'clock.
5. Adjust the intake valves on 3, 4, 6, & 8 in mentioned manner
6. Adjust the exhaust valves on 2, 5, 6, & 7
I use to have a set of valve covers with the center cut out just enough to adjust the valves. Not as much of a mess as with out one.
and did it this way...
This method works very well for a running engine.
Loosen the adjusting nut of one valve until you hear it "clicking". Slowly re-tighten the adjusting nut until the clicking stops. Tighten an additional 1/4 to 1/2 turn. Repeat this procedure for the remaining valves.
Old Nov 4, 2010 | 07:41 PM
There were two reasons for the hydraulic lifter assumption. The first, of course, being that they were able to press in all the way on one of the lifters on cylinder 8 before being replaced by the shop. The second was from the video, as the valvetrain does not sound like a solid lifter setup with just that one rocker arm clacking like that. If it is a solid lifter setup though, and I really doubt that it is, then you will need a feeler gauge at zero lash and feel for around .004" to .008" clearance as opposed to going that extra half a turn....
Old Nov 4, 2010 | 07:42 PM
neeb_usmc's Avatar
Car: 1985 Trans AM
Yes it is overwelming, but on saturday I think Im going to make a day out of it. once i get this taken care of, then I have to get the timing adjusted
Old Nov 5, 2010 | 08:50 AM
NY3RDGEN's Avatar
Car: Trans Am, Corvette
Engine: LB9, LT1
Transmission: 700R4, 4L60
Axle/Gears: 373, 259
Whats up man. Ask the mechanic the type of cam that was just installed. He should know.
Old Nov 5, 2010 | 09:47 AM
neeb_usmc's Avatar
Car: 1985 Trans AM
Just called him, I asked if he replaced the timing chain and he said "yes, those things are screwy in there" which makes me wonder if he knows he didnt do something right.
Type of cam is comp cam 268H heres a link to its specs > http://www.compcams.com/Company/CC/c...x?csid=73&sb=2
He didnt know the timing he left it at, said maybe 12 degrees
Didnt know the compression ratio
Old Nov 5, 2010 | 08:19 PM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
It sounds like a bunch of little things that are just adding up to make your car not perform the way you want it to. All the methods above are usefull, but if your like me it is easy to think about the basic mechics of your motor.
At the end of the day you want the rocker arm play to be adjusted to zero and about a half turn more when the lifter is on the base circle of the cam.
How do you know whne the lifter is on the base circle of the cam. THis will be when the rockers are at their highest position. So watch the rockers as you turn the engine over by hand. When the rocker comes to its highest point its time to adjust. If it is pushing down on the valve spring leave it alone. You will begine to realize that there are multiple rockers that can be adjusted on each revolution.
I see the car is still fuel injected. So if that is the case you need to find out how it is programmed, and what the base timing is set to in wahtever ECM is controlling the fueling, and that is what the initial timing needs to be set to.. If you cannot find this out, you will need to get the ECM programmed by somebody that can tell you things like initial timing.
Another good investment would be a Wide Band O2. The last thing you want to do is run a forced induction motor with no idea of how it was tuned without being able to monitor the AFR. If it goes over 14.7:1 at cruise or les than 12:1 under acceleration, it needs tuned or you will damage it eventually.
Old Nov 6, 2010 | 12:09 PM
neeb_usmc's Avatar
Car: 1985 Trans AM
ok the ticking was a loose rocker arm. what should timing be on my car? i have a buddy here with a timing gun now
Old Nov 6, 2010 | 12:47 PM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
If it is stock timiing it should be 6 degrees otherwise it is what ever someone set it to in the ECU. If you are using the stock ECU you need to disconnect the bypass wire before setting the timing.
Old Nov 6, 2010 | 12:58 PM
neeb_usmc's Avatar
Car: 1985 Trans AM
im going to wait till monday now for the timing. it definatly was that rocker arm, when i started it there was no noise, now it is coming back a little at a time which makes me think i should replace all of them(since the mech didnt) and/or it could just be my timing needing adjustment..
Old Nov 6, 2010 | 01:36 PM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
What is your oil pressure? Alos look at the studs they are mounted on or take a picture and show us. If they are not screw in studs they may be working out of the head.
Old Nov 6, 2010 | 01:57 PM
neeb_usmc's Avatar
Car: 1985 Trans AM
they are screw in and my oil pressure is at 30 pounds at about 1000rpm...
the boost gauge is at -15 at idle ???
Old Nov 6, 2010 | 02:01 PM
scamaro355's Avatar
Car: 92 rs
Transmission: 4L80E
yeah that would be 15" of vaccum at idle.. thats actually pretty good... that cant be to much of a cam they put in it
Old Nov 6, 2010 | 04:08 PM
neeb_usmc's Avatar
Car: 1985 Trans AM
he said it was a mild cam. hes an idiot and im fixing his mess(or at least trying to)
Old Nov 6, 2010 | 04:15 PM
neeb_usmc's Avatar
Car: 1985 Trans AM
so after finding out it was a bad rocker arm, i am looking up roller rocker kits. i am at summit.com and looking up comp cams part CCA-1418-16
the rocker arms are comp cams now so should i get the same kind you think? i have a check out ready to be paid for, this is what i have in checkout roller rocker kit part #CCA-1418-16, perma-lock rocker arm adjusters part #ARP-300-8241, and pushrods part #CCA-7808-16. my total after shipping is $301. is there a cheaper route that is just as good? thanks
Old Nov 6, 2010 | 04:21 PM
neeb_usmc's Avatar
Car: 1985 Trans AM
picture of my roller rocker now
http://i764.photobucket.com/albums/x...b_usmc/268.jpg
Old Nov 6, 2010 | 05:53 PM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
What makes you think that rocker arm is bad??? I don't see anything alarming in the picture.
I am a little concerned. If the part number of the rocker arms you sent are exactly what is on your motor then you may have an issue. The ones you posted a link to are self aligning and you have pushrod guide plates. Using the two in tandem sometimes works but sometimes can lead to binding or the valvetrain.
Also with guide plates I would recommend chromoly pushrods. You should see what you have in the motor. Pushrods are not always a standard size. You need to rotate the engine by hand and make sure the rocker are travels only on the valve tip preferably centered. If it doesn't you pushrods could be the wrong lenght and the intake will need to come off and you will need to measure for pushrods, then order. If they do check out, you can measure your current pushrod and order that size.
Note if the pushrods are the wrong length as the engine warms up you may hear slight tapping from the rockers rolling off the edge of the valve tip. This is BAD!
If you are going to cahnge out rocker arms might as well go full roller.
I haved used these in two budget builds with success
http://www.summitracing.com/parts/SUM-G6906/
Old Nov 6, 2010 | 08:36 PM
neeb_usmc's Avatar
Car: 1985 Trans AM
okay good information to know Dave. I like those ones, I was just looking at something in comparison to the ones on mine. If my push rods were fine prior to the new cam(no tapping) do you think they are the right length now? I hope so b/c otherwise I dont know who can measure them for me. I would think there right.
Old Nov 6, 2010 | 08:56 PM
neeb_usmc's Avatar
Car: 1985 Trans AM
and do you know if they can clear center bolt valve covers?
Old Nov 6, 2010 | 11:38 PM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
They clear the aftermarket aluminum ones in Jegs. For a rough check on your pushrods, have a buddy turn the engine over and just confirm the roller stays on the valve tip through the whole motion of the rocker arm. If that is the case you should be fine.
Old Nov 7, 2010 | 12:34 PM
neeb_usmc's Avatar
Car: 1985 Trans AM
okay i will look at that..
Old Nov 8, 2010 | 10:39 AM
neeb_usmc's Avatar
Car: 1985 Trans AM
i just ordered the single socker arm it will be here wednesday. I am going to throw it on and do the timing then store the car for winter. Come march I will replace the rest of the arms/pushrods and call it a day. I will update you guys on the outcome.
Oh Dave, I saw the tall valve covers in Jegs, I will order them, I just want to double check the measurements to make sure they will fit in there..
Nick
Old Nov 11, 2010 | 12:07 AM
neeb_usmc's Avatar
Car: 1985 Trans AM
Ok, I adjusted every valve tight then 3/4 turn. Now I have a loud metal on metal noise that happens when I accelerate fast. I have attached a video that is in the movement(at night) and I dont know what that could be. I dont know but it didnt do this prior to my cam/valves/lifters and I thought it had to do with my rocker arms, but now that there tightened I am lost. Any advise?
It doesnt do it in park, only in drive while moving, and I havent done timing or anything yet, so at idle it will stall out half the time and my SES light comes on also.
I know this is alot of info, any questions just ask. Id like to get this figured out, I am hoping its not my piston skirts or anything. Video isnt best but here ya go.
http://s764.photobucket.com/albums/x...-01-58_685.mp4
Old Nov 11, 2010 | 01:04 AM
scamaro355's Avatar
Car: 92 rs
Transmission: 4L80E
ok PARK the car adjust your timing!!!!!! is really sounds like some serious spark knock
Old Nov 11, 2010 | 07:13 AM
  #42
neeb_usmc's Avatar
Car: 1985 Trans AM
Yeah I do need to asap. I hope that is it and not a broken piston skirt. Thanks for the advise
Old Nov 11, 2010 | 09:56 AM
  #43
scamaro355's Avatar
Car: 92 rs
Transmission: 4L80E
if u keep running it a piston skirt wont be your problem... it'll be a hole through the top of the piston.... good luck man
Old Nov 11, 2010 | 10:21 AM
  #44
neeb_usmc's Avatar
Car: 1985 Trans AM
thanks.. yeah it has been stalling out a lot also
Old Nov 11, 2010 | 12:09 PM
  #45
NY3RDGEN's Avatar
Engine: LB9, LT1
U need a real mechanic. Trailer that puppy down to the island, Garantee you will be driving it home with a big SMILE.
Old Nov 11, 2010 | 01:42 PM
  #46
neeb_usmc's Avatar
Car: 1985 Trans AM
thats what John said. I just dropped it off to this mechanic at this shop HOT RODS up here. I know him through people, took him for a test drive and he is going to double check all my work I did and do the timing and adjust the tps and something else. He said it sounds like a detonation issue so my fingers are crossed. Im going to come to "The Island" next year, you have my word. I have family and want to come on a big meet.
Nick
Old Apr 24, 2011 | 02:14 AM
  #47
bjm1206's Avatar
bump what has happend here ?
Old Apr 24, 2011 | 03:13 AM
  #48
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Looks like it ended badly:
https://www.thirdgen.org/forums/engi...rger-sale.html
He's selling his supercharger...
https://www.thirdgen.org/forums/engi...ers-again.html
Makes you wonder if the earlier poster in this thread was onto something catching self-aligning rockers setup on guideplates...
Old Apr 24, 2011 | 03:33 AM
  #49
bjm1206's Avatar
wow crazy, it sucks when you have love and passion for some thing ie. a car and it just treats you like poop
theshackle
Sep 17, 2020 08:26 AM
Fronzizzle
Mar 18, 2019 08:29 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
B_Dubya
Aug 26, 2015 05:09 PM
BlackBoulder
Aug 11, 2015 11:15 PM
