ebay turbo kit
Old Dec 21, 2010 | 02:47 PM
1986chevycamaro's Avatar
Car: 92camaro,86 camaro
Engine: 355
ebay turbo kit
http://cgi.ebay.com/ebaymotors/1982-...item2c52a69a7a
has any one use this kit i want to buy it but im not sure this will be my first turbo set up and i dont know anything about them thanks
by the way i have a carb 355
Old Dec 21, 2010 | 04:14 PM
BigBadGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 350TPI
Axle/Gears: 3:27
Re: ebay turbo kit
I have always wondered about these kits too for my L98. Its not like you would be running alot of boost anyways, maybe 7-9 PSI on a stock engine. For $850 surely this kit is not of the best quality materials, but I think for a beginner short on funds you could buy one of these kits and upgrade the turbo, blow off valve, etc to quality name brand components later as your budget allows. I would be very interested in purchasing this as well if that is the case. Hopefully someone could chime in and explain if these kits are even good for that, and how hard the install would be for a beginner. I was going to ask too, how would one go about installing a turbo on a MAF TPI car?
Old Dec 21, 2010 | 06:48 PM
xdamxincx's Avatar
Re: ebay turbo kit
i think it would be a great way to learn about turbo's .. it doestn look bad really .. theres actually a lot of people with ebay kits doing pretty good.. your going to have mod your carb(hanger 18 diy blowthru mod)if your want to do it right ..and get a bonnet to( spectra or buy used one online)
Old Dec 22, 2010 | 01:35 PM
Engine: 355
Re: ebay turbo kit
any one has more input on this kit?
Old Dec 23, 2010 | 11:13 AM
Engine: 355
Re: ebay turbo kit
really no one knows anything good or bad about this kit?
Old Dec 23, 2010 | 05:59 PM
pajama sam's Avatar
Re: ebay turbo kit
Doesnt work... passenger side header comes in contact with spark plugs. Also the crossover does fit right.... saw all this in another post. better off getting twin turbo headers and making ur own crossover/merge pipe for turbo
Old Dec 24, 2010 | 05:35 AM
noboostnogo's Avatar
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
Re: ebay turbo kit
yeah i bought the same header kit and was trash, i ended up making my own, its a knock off version of the BBSdesign style, it would work ok if you had angle plugs heads i guess but wont fit with tall valve covers, when i got my headers the flanges were wrapped and hat to mill them to make them straight. crossover pipe was way off place and couldt even fit one of the bolts in the crossover to driver header flanges, dont waste your money this is not even a 82-92 kit , there is no such thing as a kit of our cars, thats just a sbc header kit that doesnt fit and aluminum mandrel bent pipes and a turbo, by the time you are done modifyin it u couldve made your own
Old Dec 27, 2010 | 04:51 PM
91-RS's Avatar
Car: 91 RS
Engine: BUILT 327
Axle/Gears: 3:73
Re: ebay turbo kit
keep in mind you need about $1000. worth of ignition and fuel system upgrades to run a turbo
Old Dec 27, 2010 | 10:43 PM
Engine: 355
Re: ebay turbo kit
what all you need to run turbo that be that much ? i have msd ignition and i have an electric pump with regulator
Old Dec 28, 2010 | 03:53 PM
91-RS's Avatar
Car: 91 RS
Engine: BUILT 327
Axle/Gears: 3:73
Re: ebay turbo kit
you cant use a $80. holley blue pump or equivilant. you need a good $300. pump a $200. regulator and a $350. ignition box and another $200. ign box that progressively pulls out timing as boost increases
Old Dec 28, 2010 | 07:38 PM
Engine: 355
Re: ebay turbo kit
well i think i got one of those boxes that pulls timing i used it with my nos kit on last engine
Old Dec 29, 2010 | 02:52 PM
83 Crossfire TA's Avatar
Re: ebay turbo kit
you don't necessary need to pull timing with boost if you have a way of getting an appropriate timing curve (chip burning...) or in some cases just lock out the timing and don't worry about it.
You also don't _need_ an ignition box with boost if the stock ignition is in good shape and you run reasonable plug gaps. I won't argue that it wouldn't help, but it's not necessary.
As far as fuel pumps... again, in most cases a 255lph pump in tank will feed most FI setups well into the 700hp or more range, and less than that will work for a carb setup...
Old Jan 3, 2011 | 01:12 PM
bduffey723's Avatar
Car: not a camaro anymore
Re: ebay turbo kit
there is a member on here with an ebay setup similar to this and has many miles on it with no problems ill see if i can find him.. but i personally am piecing my own "kit" together since i can do most fab work myself and can use fellow family friends as aids that have much more knowledge than i in this field
tonys91rs
Oct 10, 2015 03:31 PM
New2Chevy
Sep 28, 2015 12:35 AM
Ian Irvine
Sep 4, 2015 08:08 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
