First turbo build
Old Jan 14, 2011 | 02:55 PM
scamaro355's Avatar
Car: 92 rs
Engine: 355 stealth ram, dart heads, S480
Transmission: 4L80E
First turbo build
Ok since i dont know jack about turbos..but im still gonna do this.. i have been doing research for the past few weeks ,but anyhow basic rundown of what im working with.. 355 forged pistons,total seal TSS rings ill prolly get a set of hell fires,4340 lunati promod rods,steel crank, cam is undecided my old one was trashed, dart platinum 200cc intake heads, holley stealth ram efi speed density. I blew the first tranny apart before i was finished tuning it....then got water in the oil do to the bad intake gasket.. so it trashed the bottom end and cam im in the process of revuilding it.Im thinking a single t-76 running through a th-400 im shooting for 600 at the wheels and be drivable on the street so any input would be great! I've watched a few ppl on here do turbo builds https://www.thirdgen.org/forums/powe...blow-thru.html I hadnt messed with this car for awhile do to being fed up...lol but i found out about a week ago theres a new dragstrip goin in about 8 miles from my house.. so i figured it was time to play again..lol and if you all think 600 at the wheels is not doable with this setup.. im very open to suggestions
Old Jan 31, 2011 | 10:33 PM
scamaro355's Avatar
Car: 92 rs
Transmission: 4L80E
Re: First turbo build
well no reply's im gonna take that as being on the correct path for my goal
Old Jan 31, 2011 | 10:43 PM
ZZ3Astro's Avatar
Car: 87 Iroc
Engine: Turbocharged 5.7 Pro-Fl-XT
Transmission: 700R4 for moment
Axle/Gears: 3.25 9 inch
Weird.. I never saw this post until now and it's been up for two weeks?!
Combo sounds pretty strong to me!
Old Feb 1, 2011 | 10:40 PM
BANDITSBC's Avatar
Car: 90 gta
Engine: 5.slow turbo
Transmission: tremec tko
sounds good! saw you are looking to do a t56 swap,,, i have tremec 5speed in mine and i haven't had a chance to hit the track yet, but an automatic may be better for you. Ask around, it may spool better with the auto.
Old Feb 2, 2011 | 12:13 AM
scamaro355's Avatar
Car: 92 rs
Transmission: 4L80E
yeah i found a th-400 for 100 bucks local im gonna rebuild it with this kit http://racetransmissions.com/store/p...roducts_id/994
Old Feb 9, 2011 | 10:17 PM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
Run a TH400 and some good gears in the back (3.05-3.55) should do well on the highway too. Or pickup a 4l80e and have OD
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
New2Chevy
Sep 28, 2015 12:35 AM
87hellbird
Sep 14, 2015 05:08 PM
john204481
Sep 7, 2015 03:22 PM
