LSX/5.3 turbo set up/question
Old Feb 3, 2011 | 08:26 PM
Willie B.'s Avatar
Car: 91camaro
Engine: 5.3
Has anyone used the truck manifolds for your custom turbo setup? If so where did you get your flange gaskets from. I cant find and gaskets anywhere. Or did you make you own.
Old Feb 3, 2011 | 08:30 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: LSX/5.3 turbo set up/question
GM sells the gaskets.
Also haven't seen a truck manifold flipped build because I'm thinking the steering gearbox is in the way
Old Feb 3, 2011 | 08:41 PM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
Transmission: FLT stage 6 60e
Axle/Gears: 8.8 with 3.73's
i used the original ones that were with the manifolds
Old Feb 3, 2011 | 10:36 PM
Willie B.'s Avatar
Car: 91camaro
Engine: 5.3
I searched the web everywhere, couldn't find just the gaskets. And the ls1 manifolds have slightly differant flanges. I can find those all over. My manfolds didnt have any gaskets for the flanges. Are they actually gaskets or compression rings?
Old Feb 4, 2011 | 01:25 AM
xpndbl3's Avatar
Car: 1984 Z28
compression rings or gaskets, just hit up your local GM dealership and the parts guy should get them for you for not much money. One side of the truck flange for sure is like a giant ring shaped object, the other one is smaller, I didn't stare at the package too long for the second one.
Old Feb 4, 2011 | 04:07 AM
INTIMIDATOR Z's Avatar
Car: 1987 IROC
Engine: Turbo 293ci 4.8l
i dont know which manifolds they were but they werent cast manifolds so we were able to weld on them. oh had a turbo 5.3l in a rx7. the engine bays are almost the same. if anythign theres more room in 3rd gens.
drivers side:
dont have one of the passenger side off the car but here it is on.
heres the whole setup.
Old Feb 27, 2011 | 10:00 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
the only thing I dont like about that is all the heat you are going to have right there in front of the engine. Its cold to the touch now but that pipe is going to get very hot especially during boost when you cannot see it glow slightly red during your full throttle run. I would be scared to let a pipe like that get anywhere near the front of my engine, near my radiator, near my... alternator? is that an alternator? hmmm. and... your radiator hose? eh
Old Apr 6, 2011 | 09:48 AM
Speedfreak391's Avatar
Car: 87 iroc Arctic White w/gold ss stri
Engine: Turbo'd 5.3 in process
Transmission: T-56 w/SPEC stage 3+ clutch
Axle/Gears: 9" Moser w/3.25's
I would llike to know more about this build. What turbo, motor mounts, are you using an after market k member? I have alot of questions. Do thae truck manifolds fit in there good with the flanges? or did you have to cut them off for clearance? I am about to start a build of a T-72 5.3 in my 87 iroc very soon, so any help would be appreciated!
Old Apr 7, 2011 | 09:44 AM
Willie B.'s Avatar
Car: 91camaro
Engine: 5.3
@I would llike to know more about this build. What turbo, motor mounts, are you using an after market k member? I have alot of questions. Do thae truck manifolds fit in there good with the flanges? or did you have to cut them off for clearance? I am about to start a build of a T-72 5.3 in my 87 iroc very soon, so any help would be appreciated!
For now I'm using a pair of RB25DET turbos that i had taking up space. My motor mounts are stock 1970 camaro with the summit LSX plates. The truck manifold fit good flipped. I just had to rerun the fuel lines in a differant direction. I brought the flanges off of ebay.
Old Apr 7, 2011 | 08:17 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
You need to check out LS1 tech. Allot of people are making over 700-800 whp with stock 6.0 truck manifolds. They also have links for flanges that work with the exhaust manifolds. I am actually building my turbo 5.3 with stock 6.0 manifolds. You can use 5.3 ones. I just chose the 6.0 ones because no egr ports.
Old Apr 9, 2011 | 11:26 AM
turbo iroc's Avatar
Car: 89 iroc single turbo
Engine: 383sbc 76mm turbo 402ci ls 88mm (in
Transmission: tko500
Axle/Gears: 8.5 10 bolt 4.10 gear 28 spline axl
remember these pics are in an rx7...
Old Apr 12, 2011 | 01:15 PM
Ok, RX7. I thought this was in a third gen. I guess I will find out how they fit sooner or later. I hope they fit, or I'm going to have to get creative. That's OK though, that's when the fun starts. Chop saws, and plasma cutters are my friends!
Old Apr 20, 2011 | 10:24 PM
4.8camaro's Avatar
Car: '89 Camaro
Engine: 4.8, ls9 cam, mpt76
Transmission: Built 4l60e, 3600 stall TC
I'm doing a 4.8 swap with a mp t76 turbo and truck manifolds into my 89 camaro at the moment. If you get yours in there before me, I'll be anxious to see the clearance issues etc. Did you do anything to your engine? Good luck!
Old Apr 22, 2011 | 07:41 PM
Willie B.'s Avatar
Car: 91camaro
Engine: 5.3
The manifolds fit good, the only hood clearance issues i have is with my ugly intake.(had to buy engine cover) if you would like to see pics, they are on "another 5.3 swap" under engine swaps.
Old Apr 22, 2011 | 08:05 PM
turbo iroc's Avatar
Can't seem to find...it can you post a link please?
Old Apr 22, 2011 | 08:21 PM
turbo iroc's Avatar
Nevermind...
Old May 9, 2011 | 05:26 PM
Willie B.'s Avatar
Car: 91camaro
Engine: 5.3
Ok, I should have plan this better but heres my problem. So i finally got the engine running and one of my turbos is blown. I used these skyline rb25 turbos for mock up but i did just want to see what kind of power i make out of them. The problem is i cant find a replacement thats either (a) in my price range or (b) i dont trust(ebay with 6 month warranty). I have been looking into a single Master power or turbonetics. But that would require redoing the entire exhaust system. So would you guys redo the exhaust and go single or get the cheaper turbo bolt it on a see what you got?
Old May 9, 2011 | 07:12 PM
turbo iroc's Avatar
Did you look into rebuilding the damaged Turbo? That might be the cheapest option.
Terrell351
Jun 13, 2021 01:13 PM
Street Lethal
Apr 30, 2019 12:14 PM
lt1z350
Sep 29, 2015 01:50 PM
camaro71633
Sep 1, 2015 10:24 AM
mustangdmurder
Aug 21, 2015 07:17 PM
