Fuel Lines
Old Feb 22, 2011 | 05:58 AM
Eric89sc's Avatar
Car: 1989 camaro
Engine: 357 procharged
Transmission: turbo 400 with Transbrake
Axle/Gears: 342 posi
Fuel Lines
Im not sure where this should be put, but ill start here. I was wondering does any one else on here have a aeromotive a1000 pump and bigger fuel lines on there car? I have 10 AN supply and 8 AN return. Both lines come down the tunnel and then go into the engine bay and cross over to the passenger fender to the regulator. The problem is the gas is getting hot when I drive for a little while. Any ideas where to move the lines or other suggestions? I do have heat wrap on the lines where it is close to the exhaust.
Old Feb 22, 2011 | 07:30 AM
Slush92RS's Avatar
Car: 92RS
Engine: LS 402 inwork
Transmission: TH350
Axle/Gears: 10 bolt,3:73's
Re: Fuel Lines
I'm running the same pump and size hoses as you but i haven't got mine running yet. I'm hoping i do not run into this problem. My hoses run down the drivers side and crossover the top of my transmission, so it is away from my exhaust.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
