Procharged LT1 in my 90 Camaro
Old Apr 17, 2011 | 01:03 PM
canadiancarguy's Avatar
I have a 95 camaro with a procharger kit coming. If I like it I might put another lt1 that I have sitting around into my 90 camaro with the same setup. I have been trying to research what fuel mods need to be done to get proper fueling without detonating the thing.
I think a fuel pump and FMU come with the P1SC procharger kit, but is that enough? Seems like an FMU is a band aid solution to me. Both lt1s are 95s. The lady at procharger seemed to thing I don't need anything else, but I got a feeling that I need bigger injectors as well. Does anyone have experience with the LT1 procharger kit? Hard to find literature, mostly LS1 info available.
Old Apr 17, 2011 | 01:14 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
Re: Procharged LT1 in my 90 Camaro
if the motors are stock, you shouldnt need bigger injectors, the FMU is a band aid in my eyes, i did not like 90+ psi of fuel pressure with mine. if you want to eliminate the FMU you will need bigger injectors and a custom tune that can sense boost.
Old Apr 17, 2011 | 02:15 PM
OK here is another question, where can you get an LT1 tuned, or what can I buy to tune myself?? I see alot LS1 tuning stuff out there, but not any LT1 stuff. Also, I believe that 1993 had prom chips still, while 94-95 have an ecm?? Also 96+ needs other stuff to work with boost. I agree 90psi of boost seems a little high. I would think that 75psi would be about what maximum I'd like to run. 60 to 65 would be ideal
Old Apr 17, 2011 | 08:15 PM
I think I got it figured out. Just wasn't typing it in right when I was searching.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
Thirim
Aug 9, 2015 06:19 PM
