nitrous advice
Old May 15, 2011 | 03:50 PM
james94's Avatar
Car: 1990 IROC
Engine: Tree Fiddy
nitrous advice
Hey guys,
I have been looking at this system
http://www.summitracing.com/parts/NOS-05151NOS/
I have heard different things from different people weather to have a timing retard or not. Just hoping somebody here will settle the disputes if it is necessary or not, and if it is, how would I go about it. I dont plan on using it alot, just every now and then on the track. I have a 1990 iroc with a 350 with edlebrock shorties if that changes anything..
Thanks.
-James
Old May 15, 2011 | 06:51 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Re: nitrous advice
All it takes is just 1 time to use it wrong...
2 degrees retard for every 50 hp... and a fuel pressure safety switch is also another engine saver... You don't want it on too early 3000 rpm and above or so... do it right and your car will last a long time...
Rafael
Old May 15, 2011 | 07:11 PM
james94's Avatar
Car: 1990 IROC
Engine: Tree Fiddy
Re: nitrous advice
thanks. would you leave the time like that all the time, or just set it that way before you use it like a track day?
Old May 16, 2011 | 06:21 AM
luvofjah's Avatar
Re: nitrous advice
Some of the popular ignition boxes (MSD, etc...) have an option to adjust / retard timing when a wire is grounded (or when nitrous is active)... Look around for choices and decide what you want from the car... I got an EBL P4 Flash from www.dynamicefi.com Besides tons of tuning capabilities, it can retard the timing for nitrous, it provides an RPM window for nitrous too...
Rafael
Old May 16, 2011 | 10:22 AM
james94's Avatar
Car: 1990 IROC
Engine: Tree Fiddy
Re: nitrous advice
so you cant just adjust your engine timing? is has to be done through ignition add-ons?
Old May 16, 2011 | 11:14 AM
luvofjah's Avatar
Re: nitrous advice
Sure you can adjust it with a timing light, and some basic tools... just easier with a switch... Do a search here on how to adjust timing...
Old May 16, 2011 | 12:13 PM
james94's Avatar
Car: 1990 IROC
Engine: Tree Fiddy
Re: nitrous advice
I know how to adjust the timing, just making sure its safe to do things this way.
thanks for your help
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mrdevontay
Sep 2, 2015 08:04 PM
