question about TPI NOS kit...........(get in here---v)
Old Jun 9, 2011 | 11:31 AM
Guest
Guest
Posts: n/a
Anyways so iv pretty much srapped my procharger plans unless I strike it rich. So I won a NOS TPI kit on ebay for $385 and I read some wheir that their/the kit(s) are calibrated to use the cars STOCK timing....no chips no funny stuff.....IS THIS TRUE?
-ill be using a 100 shot 125 tops.....
--L98
Old Jun 10, 2011 | 03:40 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Re: question about TPI NOS kit...........(get in here---v)
To be safe I would retard the timing 2 degrees per 50 horsepower added and get some colder plugs
Old Jun 12, 2011 | 12:27 PM
Guest
Guest
Posts: n/a
damn....I was hoping not 2....ill givem a call and ask before I do that....just bought new plugs 2....
Old Jun 23, 2011 | 11:42 AM
Guest
Guest
Posts: n/a
I installed the kit and the instructions ?(yes I read'em..) say to use with stock plugs, stock-stock timing no chips, and a min of 92 gas (im runnen 93) and that they also dont condome use of any of their products.....
-lol-
Old Jun 23, 2011 | 02:24 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Retarding the timing 2 degrees per 50 HP is just making it safer / engine last longer...
Don't activate it below 2800 RPM...
A fuel pressure safety switch will also save you big $$$ (ie. your engine)...
Raf
Old Jun 23, 2011 | 06:17 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
i'd use a colder plug right from the start no sence in burning a piston top off or pinging it death
Old Jun 24, 2011 | 03:15 PM
Ronny's Avatar
Quote:their/the kit(s) are calibrated to use the cars STOCK timing.
I use NOS universal kit ($385 about right). Multiple jets incl. Instructions are explicit in warning to use colder plugs and reduce timing. Also only allow it to activate over 3000 rpms. There is an accessory that disallows under 3000rpms. Mine is set for 3200 rpms on and over 25 mph on. Their jetting chart is on safe side I found out.
Old Jun 24, 2011 | 05:02 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Yep. Most directions have you jet it a little rich. They figure the normal user isn't going to have a wideband or a dyno available to get it tuned exactly. Lots of members on here have ran 150 HP shot down a stock 350 without issues.
Old Jul 7, 2011 | 12:13 PM
Guest
Guest
Posts: n/a
I have sprayed it (100 shot) 10 times since the 4th of july, motor runs just fine. I HATE THE STOCK CHICK THOUGH!!!
Old Jul 7, 2011 | 03:48 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
well keep spraying it for no reason and let us know how long she lasts
Old Jul 7, 2011 | 06:49 PM
Guest
Guest
Posts: n/a
the hells that suppose to mean....
Old Jul 7, 2011 | 06:57 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
I mean if your racing it against somebody then spray it up, if your at the track spray it up. but just to use it because you have it is unneccesary and let us know how long it lasts. It'll be good to know what we can expect from nitrous.
Old Jul 14, 2011 | 11:01 AM
Guest
Guest
Posts: n/a
Itll be monday before I can get my fix.... :- (
- I was spraying it to get used to it and see what needed tweaking and what else I WOULD need to run with the spray.
I adjusted the cooling system and some small stuff inc-ding bottle blanket and a bottle heater.
I also have a planned track date in 3 weeks (3 pay checks) to see what it will do. I still need to get the 150 shot jets, and a msd blaster coil because the stock ING is just plain weak.
---also have 5.3L swap plans in the mist
5.3L + 150 shot + ***** of steal = HAULEN ***!!!
Old Oct 19, 2011 | 11:45 PM
turbosbox's Avatar
Car: 88 TPI formula
Engine: L98 Vortech
Transmission: TH700r4
I think he means he wasn't able to melt down his motor with it for no reason, so he sold the kit to me so I can attempt to melt mine down with no particular purpose in mind besides trying to break loose the rear tires.
Old Oct 26, 2011 | 06:57 PM
Guest
Guest
Posts: n/a
ummmm.......w-A-t????
69 Six Pack
Oct 5, 2015 07:51 PM
fasteddi
Sep 2, 2015 10:29 AM
redmaroz
Aug 16, 2015 11:40 PM
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
Sanjay
Aug 12, 2015 03:41 PM
