Will a tpi 350 still choke
Car: 91 Trans Am GTA
Engine: Tpi 5.7
Axle/Gears: 3:23
We all know tpi chokes at high rpm, but if i put a turbo in will it still choke. I am looking to get the best bang for my buck and boosting seems to be the way to go. I am very happy with my take off but I want more power 30+ mph any other suggestions would be appriciated. This probably has been answered if someone knows where the thread is that would be great also.
Re: Will a tpi 350 still choke
turbo tpi motors typically have the same power curve as na tpi engines just alot more of it,
power will start falling off at around 5,400 rpms and will be all done by 6,000 rpms
turbotpi has gone low 10's with the tpi and turbo355 has gone low 9's with a basically stock tpi setup, im pretty sure all he did was remove the egr bumps and gasket match the tpi.
i have only done gasket matching on mine and im looking to run low 9's with mine and twin 57mm turbos
Engine: Tpi 5.7
Axle/Gears: 3:23
So just putting a turbo on it will change 1/4 mile times that much.
Engine: Tpi 5.7
Axle/Gears: 3:23
Is there a way to do a turbo without tuning I cant find anyone locally that will tune my car
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by rob2000gt
We all know tpi chokes at high rpm, but if i put a turbo in will it still choke. I am looking to get the best bang for my buck and boosting seems to be the way to go....
Engine: Tpi 5.7
Axle/Gears: 3:23
Maybe a mild cam is the way I should go if it gives a little more in higher rpms
It really depends on how you size things.
Most stock TPI 350's run fastest when you shift them around 4600-4800 rpm, where the 305's can get into the low 5Krpm range before they really run out of breath.
Add forced induction to make up for the airflow short commings and you can use it to extend the rpm range, but most people size the turbo and the cam to still work best in the stock range. That is the most reasonable approach, but the problem with it is that on shifts your RPM drops below the NA torque peak and it becomes fairly difficult to run higher boost and control detonation.
You could size things to work past the NA rpm range and use the extra air from the turbo to make up for the deficiencies of the intake and extend the rpm range. That not only lets you run more rpm, but also allows you to run more boost at WOT, but does require much more careful part throttle tuning.
With a stock TPI setup (minor clean up) on a 350 there is no good reason why you couldn't reliably push 15-20psi boost to the mid/high 5xxxrpm range and close to 800bhp, assuming that you have the right engine combination under the intake. On a stock TPI engine you'll run out of heads and cam before you'll run out of intake airflow.
Engine: Tpi 5.7
Axle/Gears: 3:23
thank you for the info. What about the electric supercharger that on ebay for $50 has anyone tried it. I can see how it will work but dont see how it will spool up enough without putting a drain on the electrical system.
Maybe a mild cam is the way I should go if it gives a little more in higher rpms...
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Turbo + short runner intake will get you alot more rpm. Stock L98 cam is good to 5200 rpm and shift by 5500, although its dropping off pretty fast after 5200. Turbo/blower may help extend that point alittle longer. So basically its about 1000 rpm more available over stock TPI. AFtermarket TPI can also help with its larger tube diameter, it can extend rpm alittle on stock cam/stock heads as well. Siamesed TPI acts like a shorter runner intake like stealth ram or miniram so it also extends rpm range.
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
