Lets see those BLOWERS and PROCHARGERS!!!
Old Oct 30, 2011 | 03:00 PM
  #51
Guest
Guest
Posts: n/a
Re: Lets see those BLOWERS and PROCHARGERS!!!
hey.....dont be a smart a**.... :wink:
Old Oct 30, 2011 | 04:34 PM
  #52
Guest
Guest
Posts: n/a
Does anybody know what -N size the drain fitting is? Im gonna spend the money and use -N line and not some weak pcv hose....thats just FAIL.
Old Oct 30, 2011 | 06:24 PM
  #53
Guest
Guest
Posts: n/a
Testing lighting angles.....
-Also what a 1000HP+ looks like. O_O !
Attached Thumbnails Lets see those BLOWERS and PROCHARGERS!!!-pict0002.jpg   Lets see those BLOWERS and PROCHARGERS!!!-pict0005.jpg   Lets see those BLOWERS and PROCHARGERS!!!-pict0001.jpg
Old Oct 30, 2011 | 08:23 PM
  #54
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Info in sig. No data / et to post.
Old Oct 31, 2011 | 12:07 AM
  #55
Guest
Guest
Posts: n/a
I have decided to remove the crappy blueish/purple powder coat of this thing...as it is poorly done. high and low areas all over and paint runs, also on top of the volute its realy thick and done just plain wrong, guy said the blower was painted to match some car but damn this shat is UGLY! So I started picking with a knife and the areas that were already chipped off and the knife was blasting threw the crap but it was leaving just to many scratch marks for my taste so I tried some 80 grit sand paper and it works good just a bit to ruff though. Ill grap so softer grit tomorrow and see how that fairs. If any body knows a better way to do it im all ears.
Old Oct 31, 2011 | 08:49 AM
  #56
VORTECCADDY's Avatar
Engine: 383 Superchared
Transmission: 700r4 built
Just an old Paxton SN2000 on a 383. Max of 9lbs boost.
Attached Thumbnails Lets see those BLOWERS and PROCHARGERS!!!-img00153-20111024-1749.jpg
Old Oct 31, 2011 | 05:07 PM
  #57
Guest
Guest
Posts: n/a
Keepem comen guys.
Old Oct 31, 2011 | 07:27 PM
  #58
Guest
Guest
Posts: n/a
Just found out that slapping the knife on the blower causes the paint to exploded off the blower....go thing im wherein eye protection!!!
-Paint is FLYING off with even less scratch of blower housing. (volute)
Old Oct 31, 2011 | 08:10 PM
  #59
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
goto a parts store and get aircraft paint stripped. It will come right off.
Old Oct 31, 2011 | 08:11 PM
  #60
Guest
Guest
Posts: n/a
Old Oct 31, 2011 | 08:41 PM
  #61
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Its a real strong paint stripper. I use it all the time on anything needing stripped of paint, powder coating , etc..
Old Oct 31, 2011 | 09:44 PM
  #62
Guest
Guest
Posts: n/a
End of the night pics.
Got the rest of that CHEAP oil out, and poured what was left of a bottle (1/4 or less) of castrol GTX syntec 20w-50.
-Good night all, and "May the boost be with you."
Attached Thumbnails Lets see those BLOWERS and PROCHARGERS!!!-pict0002.jpg   Lets see those BLOWERS and PROCHARGERS!!!-pict0003.jpg   Lets see those BLOWERS and PROCHARGERS!!!-pict0004.jpg
Old Nov 1, 2011 | 02:09 AM
  #63
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
/N.
Old Nov 1, 2011 | 04:14 PM
  #64
Guest
Guest
Posts: n/a
http://www.youtube.com/watch?NR=1&v=DuAEaRBeCNc
^^^ Whos car is this though???
-Also, I put the drain wheir it needs to be. Was a real btch to get the plug out...
--check this out.
http://www.youtube.com/watch?v=YI1NU05aY-Y
Old Nov 2, 2011 | 08:27 PM
  #65
Guest
Guest
Posts: n/a
Paint stripper worked perfect guys!
Attached Thumbnails Lets see those BLOWERS and PROCHARGERS!!!-pict0001445-1-.jpg   Lets see those BLOWERS and PROCHARGERS!!!-pict0001445-2-.jpg   Lets see those BLOWERS and PROCHARGERS!!!-pict0001445-3-.jpg
Old Nov 2, 2011 | 08:28 PM
  #66
Guest
Guest
Posts: n/a
2.
Blower is next....after I figure a plan of attack so that NO paint stripper gets inside.
Attached Thumbnails Lets see those BLOWERS and PROCHARGERS!!!-pict0001445-4-.jpg   Lets see those BLOWERS and PROCHARGERS!!!-pict0001445-5-.jpg   Lets see those BLOWERS and PROCHARGERS!!!-pict0001445-6-.jpg
Old Nov 2, 2011 | 08:38 PM
  #67
Guest
Guest
Posts: n/a
3. more blower ***** pics.
Attached Thumbnails Lets see those BLOWERS and PROCHARGERS!!!-pict0001.jpg   Lets see those BLOWERS and PROCHARGERS!!!-pict0002.jpg   Lets see those BLOWERS and PROCHARGERS!!!-pict0003.jpg
Old Nov 2, 2011 | 08:39 PM
  #68
Guest
Guest
Posts: n/a
1 more.
Old Nov 2, 2011 | 08:41 PM
  #69
92Z's Avatar
92Z
That blower was originally for a LT1 system. The blower mounts up-side down on those applications. You can also tell because the mister nozzle is in the LT1 position. If there is a drain plug in the backing plate at the 6 o'clock position, you can move the fitting in the cover to the backing plate and run the blower in the typical 3rd gen configuration. Another way to tell if the original app. was LT1, is to mark the mister nozzle and pull it out, when looking at the end if it you will see 2 holes (instead of the normal 1 hole). This second hole (on the angle) lubricates the input bearing in the up-side down position. Any questions, call Procharger. Hope this helps.
Old Nov 2, 2011 | 08:53 PM
  #70
Guest
Guest
Posts: n/a
I think mine has 3, some oil still in the blower so im not gonna turn it over and have another oil down (lol).
Old Nov 2, 2011 | 09:11 PM
  #71
Twin_Turbo's Avatar
Do you have the nozzle with the angle? The tip has a chamfered side and has 2 openings. This is an LT nozzle. I have been looking or one, ATI will not sell one to me. They want me to send in my SC which would cost me hundreds of dollars. Insane!!! I need a spare nozzle for the LT1. A normal orientation will not need the nozzle. I will buy you a new nozzle or send you a normal one. They have a straight spray pattern, not angled,
Old Nov 2, 2011 | 09:20 PM
  #72
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
We need some psi and dyno numbers here guys!
Here is mine...661rwhp @21psi and 4900 rpm on a Mustang dyno.
Broke up there due to coil... Will be back on 16psi, meth, and new coil hoping for 650rwhp on a dynojet(dont wanna run 21 psi..)
Old Nov 2, 2011 | 09:23 PM
  #73
Guest
Guest
Posts: n/a
Thats my dream setup you have their, waiting on street vids!!!
Old Nov 2, 2011 | 09:55 PM
  #74
Guest
Guest
Posts: n/a
3 holes, angled side.
Old Nov 2, 2011 | 10:43 PM
  #75
MPIpowered4x4's Avatar
Originally Posted by DAVECS1
Made the new universal Vortec kit fit my car. It was relatively easy. I redrilled the holes in the mounting bracket to position everyithing 1.5" lower then reclocked the charger. Then everything fit under the hood.
I also got them to send the T-type charger from the big block kit for a couple hundred dollars more. So for less than 2500 dollars I have a brand new high HP capable blower set up.
So the motor was built for boost, but as luck would have it this happened 2 weeks after the fun began.
So I have decided to take it to the next level.
The short block is on the way, then I have some valvetrain work to do:-)
WHAT KIND OF LIFTERS ARE THOSE?? (BRAND)
Old Nov 2, 2011 | 11:37 PM
  #76
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
COMP unfortunately.
Old Nov 3, 2011 | 01:13 AM
  #77
Guest
Guest
Posts: n/a
Blower case done, was A REAL BICH!!!!!!!!
Attached Thumbnails Lets see those BLOWERS and PROCHARGERS!!!-pict0004.jpg   Lets see those BLOWERS and PROCHARGERS!!!-pict0005.jpg   Lets see those BLOWERS and PROCHARGERS!!!-pict0006.jpg
Old Nov 3, 2011 | 07:41 AM
  #78
Twin_Turbo's Avatar
Yes, that's it. Are you willing to trade or trade w/ me putting money towards it? I really need it and I'm not sending the SC back to ATI.
Old Nov 3, 2011 | 09:16 AM
  #79
Guest
Guest
Posts: n/a
Yes, cash + a BRAND NEW IN THE BOX/PACKAGE 1.
Old Nov 3, 2011 | 09:22 AM
  #80
Twin_Turbo's Avatar
I don't have brand new in the box ones, they don't sell them brand new to customers. They only sell them brand new installed by them. That's the problem.
Old Nov 3, 2011 | 04:44 PM
  #81
Guest
Guest
Posts: n/a
Has it been used?
-Procharger support is getting gayer by the day....
Old Nov 3, 2011 | 04:46 PM
  #82
Twin_Turbo's Avatar
Of course, the nozzle is in my S/C now
I already conitacted Greg Carroll, maybe he can get me the correct one.
Old Nov 3, 2011 | 04:56 PM
  #83
Guest
Guest
Posts: n/a
Ask him to email you the 3rdgen p600b parts kit list with all the part numbers on it, I asked a guy their to email it to me and I got the feeling that he wasnt going to and he did just that....NOTHING!
Old Nov 3, 2011 | 05:07 PM
  #84
Twin_Turbo's Avatar
What do you need? The nozzle??
Old Nov 3, 2011 | 05:17 PM
  #85
Guest
Guest
Posts: n/a
No, the whole damn list of the parts numbers for the 82-92 F-body p600b kit.
-Damn prochargers C.S. ****....they are out to rape us not put us out front.
Old Nov 3, 2011 | 05:23 PM
  #86
Twin_Turbo's Avatar
Oh, i have a manual with the complete aprts list. I can get the numbers for you this weekend. It's for 88 up though. I only used the bracket, the rest I made myself. Not too hard.
What all do you need? Everything but the head unit?
Old Nov 3, 2011 | 05:56 PM
  #87
Guest
Guest
Posts: n/a
Thanks, and my car is an 88, I need the parts list for everthing, and need everything.
Old Nov 3, 2011 | 09:53 PM
  #88
kevin labrash's Avatar
awesome car,just bought the new edelbrock carb supercharger part #1551.how does your's work on the motor
Old Nov 4, 2011 | 07:48 PM
  #89
Guest
Guest
Posts: n/a
Did you still need this nozzle? Cash in the mail with your nozzle?
Old Nov 4, 2011 | 08:03 PM
  #90
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Have you checked over here for the list you need?
http://www.superchargerhelp.com/index.php
Why not just trade him even up? used nozzle for used nozzle. You both get the right part you need and everyone is happy?
Old Nov 4, 2011 | 09:42 PM
  #91
Guest
Guest
Posts: n/a
Didnt ask you but o-well.
Hundreds of dollars vs a few dollars...
Old Nov 4, 2011 | 10:22 PM
  #92
Twin_Turbo's Avatar
Old Nov 4, 2011 | 10:30 PM
  #93
Guest
Guest
Posts: n/a
What Procharger was gonna charge....
Old Nov 5, 2011 | 04:22 AM
  #94
Twin_Turbo's Avatar
I have to pay for shipping mine to you and yours back too, and I have to pay taxes over the shipment back to me, either way it's already costing me a lot of money (parts are up to 3 times as expensive here as over there)
Old Nov 5, 2011 | 09:54 AM
  #95
Guest
Guest
Posts: n/a
Your not in the US? When are you moving over here?
-and wheirs that parts list?
Old Nov 5, 2011 | 11:23 AM
  #96
Twin_Turbo's Avatar
Dude chill, I will get the damned list tomorrow. I have to drive 60 miles just to get it.... what's up with you? Am I on your dime?
Old Nov 5, 2011 | 11:35 AM
  #97
Guest
Guest
Posts: n/a
Naw, i was just wondering and am not mad or anything. My bad man.
Enjoy:
http://www.youtube.com/watch?NR=1&v=bbqahHT44g4
Also....me and my bank just won the fraud case against fle-bay. Punk-a** fle-bay (lol....) better learn not to fuc* with "THE PAT" ever again....AND TO RESPECT MY AUTHORITAAAA!!!
http://www.youtube.com/watch?v=5c11Z-33PSU
Old Nov 6, 2011 | 12:25 PM
  #98
Twin_Turbo's Avatar
I looked and couldn't find the manual, sorry.... I have no idea where I left it. It wasn't with the spare SC parts
Old Nov 6, 2011 | 02:52 PM
  #99
Guest
Guest
Posts: n/a
What spare S/C parts do you have?
Old Nov 6, 2011 | 03:55 PM
  #100
Twin_Turbo's Avatar
A whole bunch of hoses, pipes, clamps and a complete bracket as well as a dual intercooler setup but I'm keeping it all since I'm probably going to stick a SC on my truck since I have one of those vortech carb boxes for it.
