Lets see those BLOWERS and PROCHARGERS!!!
Old Oct 26, 2011 | 10:35 PM
Guest
Guest
Posts: n/a
Hot off the UPS truck today, my blue-ish purple P600B!
Gonna be stock pilen parts for next years project.
-hint, Procharger + F.I.R.S.T injection + boltons + FMIC/intercooler spray bar.
Lets see those blower setups (no turbos).
Attached Thumbnails Lets see those BLOWERS and PROCHARGERS!!!-pict0048.jpg   Lets see those BLOWERS and PROCHARGERS!!!-pict0045.jpg   Lets see those BLOWERS and PROCHARGERS!!!-pict0036.jpg
Old Oct 26, 2011 | 10:42 PM
Guest
Guest
Posts: n/a
Re: Lets see those BLOWERS and PROCHARGERS!!!
damn this cheap walmart camera....
Old Oct 27, 2011 | 01:51 PM
Guest
Guest
Posts: n/a
Just got done putting oil in the blower so its not sitting dry (REALY messy job...btw)
Come on guys....wheirs those blowers!?!?!?!
Old Oct 27, 2011 | 02:19 PM
Twin_Turbo's Avatar
Old Oct 27, 2011 | 03:05 PM
Guest
Guest
Posts: n/a
How much boost?
Old Oct 27, 2011 | 03:22 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by patin88z
Hot off the UPS truck today, my blue-ish purple P600B! Gonna be stock pilen parts for next years project. hint, Procharger + F.I.R.S.T injection + boltons + FMIC/intercooler spray bar.....
Hmm, someone seems to be a happy camper....
Old Oct 27, 2011 | 03:53 PM
Guest
Guest
Posts: n/a
YESSS!!!
and of course my pro choice LS/what buddys GREATLY approve......
Old Oct 28, 2011 | 01:33 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Ah what the hell
My best time so far with 12psi was 11.7 with like no tuning done. Went to the track the last time and picked up another 3 mph after some timing changes but had traction issues after, don't see why mid to low 11's wouldn't be possible or better with more tuning and proper slicks. This is on a 3900+Ibs race weight car at 2200' altitude track for what it's worth.
Old Oct 28, 2011 | 08:32 AM
Guest
Guest
Posts: n/a
When yall post, tell how much boost and whats your E.T.
Old Oct 28, 2011 | 08:41 AM
Twin_Turbo's Avatar
no data yet on mine.
Old Oct 28, 2011 | 08:43 AM
Twin, can you post a little about on how you modified that stock throttle body...?
Edit: Never mind, it was TTOP350....
Old Oct 28, 2011 | 09:50 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
305
14#'s
12.6 1/4 with 1.79 60'
110 mph
Old Oct 28, 2011 | 10:45 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Nice looking Procharger patin88z. Always loved you're ride too Tony - clean!
Here's my 408ish SBC with a Magnacharger. 7 pounds of boost, never ran at the track (yet).
[IMG][/IMG]
The rest of it:
[IMG]//[/IMG]
Old Oct 28, 2011 | 12:20 PM
Beater79TA's Avatar
Here's a pic of the cog driven F1A on my toy...
Still need to finish the battery relocation to the trunk and get the intake piping painted to match the car or at least thermal coated so it looks better.
Old Oct 28, 2011 | 03:15 PM
How is hood clearance, did it have to be cut with the F1A...?
Old Oct 28, 2011 | 04:15 PM
Beater79TA's Avatar
The F1A fits fine. The stealthram required a cowl hood though.
Old Oct 28, 2011 | 04:24 PM
I heard about varying brackets through ProCharger, as some of them (possibly the v-belt setups) need hood modification because they sit too high, while the serpentine setups sit lower and clear the hood a lot easier. Can anyone confirm that, as I'm considering one for a '92 GTA I'm looking to buy from a friend...
Old Oct 28, 2011 | 04:31 PM
Tony89GTA's Avatar
Car: 89 GTA
If the kit is for a thirdgen don't see why it wouldn't fit, mine clears fine.
Old Oct 28, 2011 | 04:34 PM
Beater79TA's Avatar
Correct. If the kit is for a thirdgen it will fit. But you need to start with the 3rd gen D1 kit and not the P600 kit. The brackets are different and the P600 bracket will not work with a D1 or F1.
Guest
Guest
Posts: n/a
Keep it up guys, American style v-8s....fast and loud....with "A BELT DRIVEN A** WHOOPEN!"
-cheap walmart digital camera makes it look more purple than it really is....also on my p600b...the drain is ON TOP of the blower....never seen 1 like this, can someone explain this? Mabye an upgrade/model revision? Dont realy wanna call procharger as you know how they are sometimes.....
Attached Thumbnails Lets see those BLOWERS and PROCHARGERS!!!-pict0002.jpg   Lets see those BLOWERS and PROCHARGERS!!!-pict0003.jpg   Lets see those BLOWERS and PROCHARGERS!!!-pict0004.jpg
Old Oct 28, 2011 | 04:38 PM
Not sure if your running a D1SC or not, but those fit fine. I believe, or was under the impression, that the F1 unit's have trouble cleaing the hood's on our cars though, and that the hood needed to be cut. If it doesn't, then that is great news then, but I just needed to be absolutely sure before I pull the trigger on a purchase. However, this here is what I didn't want to do to the hood though...
http://www.streetfire.net/video/car-...shop_49653.htm
http://www.youtube.com/watch?v=DzLOk-WMXuQ
Old Oct 28, 2011 | 04:40 PM
Beater79TA's Avatar
With the amount of noise a cog belt F1A with the Procharger race valve puts out, delivering *** whoopings on the street isn't that easy. The only people that really want to try it actually can beat it. Ricers don't even bother when it pulls up next to them. It's a little too obvious there is a large blower under the hood.
That and the gas mileage is so attrocious when you floor it that I just don't drive it that often.
Old Oct 28, 2011 | 04:43 PM
Beater79TA's Avatar
The F1 and F1A fit fine when you use the serpentine bracket from the 3rd gen D1SC kit. The larger ones like the F1R, F2, and F3 don't fit. Those have issues clearing the wheel well too. Check the specs on the Procharger website but I believe the F1, F1A, and D1SC are physically the same case size. The impellors and step up ratios are different though.
Old Oct 28, 2011 | 04:44 PM
I believe the F1, F1A, and D1SC are physically the same case size. The impellors and step up ratios are different though....
That is exactly what I wanted, needed and was hoping to hear...
Old Oct 28, 2011 | 04:46 PM
Guest
Guest
Posts: n/a
Lol I cant hold my hand still enough to take pics....heres another though.
Old Oct 28, 2011 | 04:48 PM
Beater79TA's Avatar
Just watch the pulley size you run on the blower. Both of the posted videos showed pulleys that looked to be larger in diameter than the blower casing which could cause some serious issues.
Old Oct 28, 2011 | 04:58 PM
Tony89GTA's Avatar
Car: 89 GTA
Oh sorry should have read your post better, yeah mine is just a D1sc.
Old Oct 28, 2011 | 08:53 PM
Pocket's Avatar
Car: 91 Trans Am
Love me some superchargers
They make any car better
Old Oct 28, 2011 | 09:09 PM
Guest
Guest
Posts: n/a
^^^Damn................
-does anybody know why my drain is on top of the blower?
Old Oct 28, 2011 | 10:48 PM
Pocket's Avatar
Car: 91 Trans Am
Is the oiling system self contained or does it tap into the engines oil?
Old Oct 28, 2011 | 11:00 PM
Beater79TA's Avatar
Pretty sure the P600 is not self contained and taps into engine oil which explains the fitting on the top for one line and another plug on the bottom for the return.
Old Oct 28, 2011 | 11:36 PM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
Made the new universal Vortec kit fit my car. It was relatively easy. I redrilled the holes in the mounting bracket to position everyithing 1.5" lower then reclocked the charger. Then everything fit under the hood.
I also got them to send the T-type charger from the big block kit for a couple hundred dollars more. So for less than 2500 dollars I have a brand new high HP capable blower set up.
So the motor was built for boost, but as luck would have it this happened 2 weeks after the fun began.
So I have decided to take it to the next level.
The short block is on the way, then I have some valvetrain work to do:-)
Old Oct 29, 2011 | 12:23 AM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
Pocket, you finally got that running? I was always wondering where that project went. What kind of power are you running? I bet that single charger is putting out more power than the duals but taking the dual supercharged one to car shows would be interesting. lol
Old Oct 29, 2011 | 06:24 AM
Guest
Guest
Posts: n/a
No, theirs the inlet oil hose ON THE SIDE, and the return IS ON THE TOP of the blower.
(see previous pics)
Old Oct 29, 2011 | 07:07 AM
Twin_Turbo's Avatar
It mounts the other way around from what you have in your pics.
Old Oct 29, 2011 | 02:04 PM
Guest
Guest
Posts: n/a
ok......so WHY would they make it mount up side down then?? So wheir it says "procharger" by the pulley would be upside down....that makes no since for them to do that....
Old Oct 29, 2011 | 02:21 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
dammit i want a procharger with my FIRST
Old Oct 29, 2011 | 04:42 PM
Guest
Guest
Posts: n/a
GET 1 DAMN IT!!!!!!!!
http://cgi.ebay.com/ws/eBayISAPI.dll...=p5197.c0.m619
http://www.ebay.com/itm/PROCHARGER-P...77327229861591
http://www.ebay.com/itm/160672185720...84.m1426.l2649
-Finished flushing the blower trans and cleaning up ALL the oil. Somebody call the E.P.A! Also re-clocked blower to re-postion the drain on bottom.
Attached Thumbnails Lets see those BLOWERS and PROCHARGERS!!!-pict0010.jpg   Lets see those BLOWERS and PROCHARGERS!!!-pict0011.jpg   Lets see those BLOWERS and PROCHARGERS!!!-pict0013.jpg
Old Oct 29, 2011 | 04:53 PM
Guest
Guest
Posts: n/a
Drain ports covered. GTFO and ST-FO DUST/DIRT!!!!
Old Oct 29, 2011 | 05:22 PM
Guest
Guest
Posts: n/a
That and the gas mileage is so atrocious when you floor it that I just don't drive it that often.
1. ....naw, ppl -WILL- want a piece of that "belt driven a** whoopin"
2. What do ricers know? Thats right....not a damn thing...all they know is what Dominick Torreto, and Brian Oconner have taught them.
3. Only real wrenchers know what a blower sounds like. just tellem its a noisy alternator......
4. Gas mileage.....(insert prius joke).
5. Like the saying goes....boost gets you laid.
6. BOOST FOR LIFE!!!
Old Oct 29, 2011 | 05:31 PM
Twin_Turbo's Avatar
You can mount it with procharger readable and the pulley on the underside but you will have to move the drain to one of the other ports. There should be allen plugs in it. Mine is a custom setup, the normal F body kit has the procharger mounted with the pulley on the bottom. Yours came off someone's custom setup too...or maybe a mustang, don't know. So, if you want to install it as intended by procharger, move the drain
Old Oct 29, 2011 | 05:36 PM
  #42
Guest
Guest
Posts: n/a
I think it did com off a stang....those plugs look like THEIR IN THEIR....gonna try that now...
-My biggest key doesnt come close to fitting.......to the parts store.
--errr....mabye tomorrow....eaten.
Old Oct 29, 2011 | 05:48 PM
  #43
Twin_Turbo's Avatar
Just mount it like I did, that's the stock F body bracket. It mounts like that no problem. I did it on purpose for clearance w fans and other junk I have in there. The tensioner is a bit less efficient this way, so you'll have to install a belt that's tight with the tensional all the way down.
Old Oct 29, 2011 | 06:12 PM
  #44
Guest
Guest
Posts: n/a
Naw, ill just do it right the first time....plus I want it mounted the way its suppose to be anyway.
Old Oct 29, 2011 | 06:51 PM
  #45
Twin_Turbo's Avatar
There is no set way to mount it, hence all the plug locations on the thing.
Old Oct 29, 2011 | 07:07 PM
  #46
Guest
Guest
Posts: n/a
Whats the part number for the KN cone for these? Also post pics of that sexy super bee that your trying to hide back their.
http://www.youtube.com/watch?NR=1&v=sDORBRP8y8I
Old Oct 29, 2011 | 08:53 PM
  #47
Guest
Guest
Posts: n/a
Ah what the hell
How much boost?
Old Oct 30, 2011 | 12:26 PM
  #48
Confuzed1's Avatar
Car: 83Z28 HO
How much boost?
Old Oct 30, 2011 | 01:48 PM
  #49
Guest
Guest
Posts: n/a
Originally Posted by Confuzed1
lol, wrong person.
Old Oct 30, 2011 | 01:53 PM
  #50
lol, wrong person.
Confuzed1 was pointing out that Tony89GTA already said how much boost in post #8...
My best time so far with 12psi was 11.7 with like no tuning done. Went to the track the last time and picked up another 3 mph after some timing changes but had traction issues after, don't see why mid to low 11's wouldn't be possible or better with more tuning and proper slicks. This is on a 3900+Ibs race weight car at 2200' altitude track for what it's worth...
