D1sc upsetting garbage
Old Jul 12, 2012 | 11:50 AM
  #51
prossi's Avatar
Re: D1sc upsetting garbage
85berlinetta383, did you get an accurate NA baseline yet?
Old Jul 12, 2012 | 12:01 PM
  #52
85berlinetta383's Avatar
no real accurate na baseline, it was a rush dyno session at 10 at night to try to get my racing at the track next morning. I will soon im waiting on moser and an airline to have my new center section here. Then the car is mobile again.
Old Jul 12, 2012 | 07:48 PM
  #53
vwdave's Avatar
Originally Posted by project89
super pully should fix that problem but it aint cheap,
http://www.atiracing.com/superpulley/index.htm
$550 is alot cheaper than a broken crank.
That is so damn cool though.
Old Jul 17, 2012 | 02:24 PM
  #54
well last night I got a new gates belt, instead of a gatorback, tightened the crap outta the belt and had the blower pulled back towards the strut brace keeping it from flexing towards the front of the car, took it for a spin and actually made 8 lbs of boost!! first gear is basically useless even with 3.50 gears. mt street radials sure don't work like there drag slicks....i'm sure my boost guage was reading right before on the dyno being 4-5 lbs of boost. this bracket is so flimsy its terrible. i notice on most of your thirdgen kits you have a bracket that goes to the back of the alternator, mine doesn't have the spacers behind the pro charger unit to allow that bracket to be used, I also have standard length charger pullys, not the longer shanked ones i'm seeing in the new kits. we did make out own support to go to the block above the power steering, it helps but with the insane tension you need to build boost the thing is still too flimsy.
Old Jul 17, 2012 | 02:32 PM
  #55
I did also find one small boost leak. in my D1sc head unit where all the bolts hold the impeller case on mine had to be clocked, in doing this one hole cant have a bolt in the unit in the position we need it. Its blowing air steady out of there.... Hot air to boot.. the air inlet right above the header on the driver side is a terrible design in my opinion. anyone switched theres up a bit to get cold air coming into the charger? i;m sure my IAT's are 200 F real sweet for making power. i'm wrapping my headers today to try to keep some of the heat out of my engine compartment.
Bubbajones_ya
Oct 25, 2015 08:01 PM
ban1one
Aftermarket Vendor Review
Sep 15, 2015 10:10 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Willie
Jun 13, 2001 12:24 AM
Willie
May 14, 2001 10:07 PM
