High idle and backfire after sc install
Old Jul 15, 2012 | 11:08 PM
1fastrock's Avatar
Car: 89 Camaro IROC
Engine: 383 Stroker
Transmission: turbo 400
Hey everyone,
My setup is an 89 camaro with a 383 carburated small block. I just finished installing a vortech supercharger with a full msd setup. I just got it dyno tuned and they said that the timing and everything was set right. But my problem is that it idles super high (1200 in neutral and 1000 in drive), diesels when I shut it off, and back fires through the exhaust. To me it sounds like a the timing is off but I want to make sure before I go back to the dyno shop with it.
Thanks in advance
Steve
Old Jul 16, 2012 | 04:04 PM
TransAmGTA88's Avatar
Car: 88 GTA, 74 T/A
Engine: 383 stroker (Procharged)
Transmission: TH400 w/brake (new 2013)
Axle/Gears: 12-Bolt S60 - 3.73 (new 2013)
Re: High idle and backfire after sc install
Is your carb. a blow thru set up? Where are the idle mixture screws set at? 1 1/2 turns out is a common place to start. Personally I would check the time first and go from there.
Old Jul 16, 2012 | 04:15 PM
1fastrock's Avatar
Car: 89 Camaro IROC
Engine: 383 Stroker
Yeah it is a blow through set up with a box.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Andrew6.688
Dec 13, 2015 10:59 AM
db057
Aug 22, 2015 08:17 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
