How do these plugs look?
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: How do these plugs look?
those look good you want alittle color on the porcelin you don't want it to white as it would be lean
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Light brown is just about right. Maybe even a hair rich but maybe not. Hard to tell without having the car on a dyno with A/F.
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by Tomuch7
They are out of a 327 SBC with a Weiand 177 blower and a Holley 750 Dual line double pumper...
Although something tells me you already know the answer to your own question...
Cut the threads off. The depth of the porcelain determines what RPM that you're looking at from my understanding. By memory the higher RPM is further towards the wire side. You're pretty much looking at the idle as-is.
Car: 94 camaro z28
Engine: lt1
Transmission: 4l60e
Well the plugs have about 10 miles on them but here is the reason why....When my uncle bought the heads we had to have them machined to work with a blower and flat top pistons that where already in the block so when they came back we put them on and just bought a set of NGK plugs with a .407 reach well after driving it for about 4 years just to car shows and about 6 sets of plugs all fouled out after some help from the Corvette Forum one of the guys suggested that i was running too short of a reach plug in my aluminum heads...he noticed that in one of the plug pictures that the reach was too short...so i went out pulled a plug and used a mirror to see down in the hole and at first glance all you saw was the clean threads but at just the right angle with a flash light i saw a second set of threads and i about died...so i called my uncle over and he saw them too we switched them out for NGK TR5 .708 reach and she runs great no carbon build up...here is what all we have changed to find this...Holley main jets 20 times up and down all new needle valves and floats, power valves evey size new fuel line, new fuel pump ,new fuel tank, new fuel sending unit ,set the timming, new fuel filters and a couple of smaller carbs bolted on and still foulled plugs...i did find some rust in the fuel lines but never had any problems....so frusturation!!!!!
wigmobile
Feb 26, 2025 02:56 PM
89 formula TPI
Sep 7, 2015 11:06 AM
