Cylinder wall to valves distance for a turbo
Old Apr 30, 2013 | 09:39 PM
Kurtis2short's Avatar
I'm building a ls1 iron block 6.0 standard 4.00 bore right now. I'm putting a set of ls3 heads on it with 2.20 1.60 valves. As it measures right now I have a 1/8 of an inch between to walls and the valves. I do plan on boring my block .030 over but that's not gaining that much more room. Is the a rule of thumb when it comes to cylinder wall valves distance between the two for turbo applications. If so I'd like any input.
Old May 4, 2013 | 04:07 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: Cylinder wall to valves distance for a turbo
No real rule of thumb per se, but more room equals less shroud. Less distance won't hinder your engines' performance, it just won't maximize it...
New2Chevy
Sep 28, 2015 12:35 AM
Magman
Sep 12, 2015 10:43 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
db057
Aug 22, 2015 08:17 PM
86White_T/A305
Aug 17, 2015 12:16 AM
