Found a set of crate engine heads. 76cc. Any good for my turbo build?
Old Jul 14, 2013 | 09:55 PM
FIRECHICKEN's Avatar
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
Hey guys. Need a quick opinion on if these heads I found on Craigslist would be good for a turbo engine. They are 76cc and the number is 10147898 what I can find on them says they are 1995-1998 crate engine heads.
I'm lookin to lower my compression ratio for more boost. I figure at $150 it might be a good investment.
Also any idea what going from a 64 to a 76 cc head would do to my compression exactly??
Old Jul 16, 2013 | 10:05 AM
Drac0nic's Avatar
Re: Found a set of crate engine heads. 76cc. Any good for my turbo build?
You'd gain about 12CC chamber volume, I believe it would be worth slightly over a full point drop in compression. www.turbofast.com.au has a compression ratio calculator. Good to fudge with. Besides that what heads do you have now? The Goodwrench Quest did an engine with heads that are probably similar. Should be pretty decent, just do some pocket porting and toss em on.
Frozer!!!
Jan 19, 2024 04:55 PM
midias
Aug 22, 2015 01:42 AM
jharrison5
Aug 19, 2015 05:53 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
antares57
Aug 6, 2015 07:47 AM
