Help with Descion on injectors.
Old Jul 21, 2013 | 10:57 PM
cdawg's Avatar
Hey Guys/Gals.
I've got a 88 Iroc im putting back together i am doing a turbo build on, i'm not positive on how much boost i plan to run, but do plan to use E-85.
This is what i've got, i've got 4 RC1000's on hand, i could buy 4 more...
or i got 8 DSM 450's injectors ready to go, i do want to use E-85 as well though for tuning and HP use.
Whats all your opinions?
Block info :
350 - bored out to 355, dished piston
350 Big style truck heads for lower compression for more boost, i dont have numbers by me but i can look at em tomarrow.
stock bottom end, just refreshed
Old Aug 5, 2013 | 04:37 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Help with Descion on injectors.
Really need to know a power goal and complete motor specs to determine that but a 450 cc injector is basically a 42 lb per hr inj and they are good for 550 whp or so on gas. On e85 it probably would be 400-450 whp.
I would buy siemens 60's to be safe if you plan on over 450 whp
Old Aug 6, 2013 | 09:17 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
here's a formula http://www.shopsupercharger.com/t-Wh...arger-Kit.aspx
92-Formula
Dec 12, 2015 10:34 PM
dusterbd
Sep 29, 2015 08:40 AM
BBSDesigns
Sep 22, 2015 03:08 PM
BLK87Z
Sep 18, 2015 11:29 PM
webeeZ28
Sep 14, 2015 12:00 PM
