Fueling Ideas for S/C
Old Aug 5, 2013 | 10:42 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
While on the Dyno last Sunday:
87 IROC using -6 AN fuel supply and feed line with a 434 on a Vortech S/C using a 3:48 pulley got me 5 lbs of boost at 6500 rpm and I couldn't get enough fuel while in boost and it wanted to go lean...
Determined that it was only running a Walbro 255 fuel pump... So that was why it was running lean!!!
So, I have now decided that I really want to play.. I am buying 3:125 pulley which should get me around 12 lbs of boost at 6500 rpm.. So, with this I also know I need to get rid of the fuel supply line and probably need the -10 AN or -12 AN fuel line not sure which.. And I am look at the Aero1000 but now sure how to rig this up in the existing tank around the existing sender... Anyone with pics and advise would be greatly appreciated...
Old Aug 5, 2013 | 11:04 PM
project89's Avatar
Re: Fueling Ideas for S/C
why not just get an areomotive 340lph pump
Old Aug 5, 2013 | 11:32 PM
T/Aperformance's Avatar
Car: 1987 Trans Am
Engine: 355 tpi
Transmission: 5 speed
Why not use the Walbro 400lph fuel bump, It is a bit bigger than the 255 But fits in our tanks like the 255.
Old Aug 6, 2013 | 12:43 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Can our stock wiring handle that? How much HP would that support?
Old Aug 6, 2013 | 01:34 AM
project89's Avatar
damn i didnt know anyone made anything bigger then the aremotive 340lph pump already
Old Aug 6, 2013 | 07:36 AM
ibmtech's Avatar
Car: 1987 IROC-Z
Exactly,, I am pushing almost 700 now, and I need to find out what the 400 is capable of supporting..
I do like the idea of the areomotive 340lph pump that Project89 suggested... Hopefully he can chime back in with details and specs on what it can support for HP and wiring capabilities...
Old Aug 6, 2013 | 09:28 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Single 255 on high voltage and large -10 line with lower pressure could squeeze 550-600 whp. But thats taxing the pump hard lol twin walbros would be easiest imo unless you can fit the 340-400 lph pumps in stock tank
I have not seen results with single 340 pumps and didnt know 400 existed. Will research these because i may need to do twin 340's soon.
If you cant try a 4th gen plastic tank. They have a bigger hole at the top. Easier to fit twin 255's on those tanks.
PM Lonnie P for ideas. He does fuel systems and could let you know if a single 340 or 400 is doable or recommend a twin 255
-8 feed line is all you really need. To be honest if you have enough pump -6 can make 700, but its harder on the pump. -10 if you can afford that would give most room to grow and be easier for pump to handle. Larger the line, less pressure is needed to flow fuel so you get more out of the pumps
Old Aug 6, 2013 | 03:14 PM
Tony89GTA's Avatar
Car: 89 GTA
Found this info on the walbro 400lph off another website. Looks like it came to market a few years ago, first time I ever heard of this pump.
Old Aug 6, 2013 | 11:02 PM
project89's Avatar
i have a flow/voltage/amperage chart for the 340lph pump somewere , when i find it ill post it for ya .
and yes the 340lph pump is a drop in pump , i have 2 in my iroc
RazorN8
Jan 7, 2022 11:44 AM
fasteddi
Sep 2, 2015 10:29 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
Kaweh
Aug 9, 2015 02:54 PM
