Another Turbo 305 TPI question!
Old Jan 30, 2014 | 08:03 PM
Soon2beBad91Z28's Avatar
Please bear with me, I have a 91 Camaro with a 305 TPI and I found a Subaru Wrx turbo, blow off valve and intercooler on craigslist for pretty cheap ($150, 90k miles and no shaft play). I was curious about what I would have to do to put this turbo on my engine. I know I have to upgrade my injectors (I already have a set of LT1 injectors that I can put in), get a computer chip (because the factory computer only adjusts to 20% larger injectors), and fabricate piping (I have necessary tools and supplies) along with buying a set of headers. I would have to get a boost controller and I was wondering how that would wire in, and I know I would have to also install an adjustable fuel pressure regulator. I know this turbo puts out 15 PSI max, but I would most likely try to run it at more conservative 5-8 PSI (because the engine is stock). I'm not looking for huge HP gains, just a lil more power that I can do on the cheap hopefully.
Also, no comments about engine swaps please! I can't afford to at the moment and I am looking for replies about my topic and nothing else. Thanks for any useful input!!
Old Jan 30, 2014 | 08:50 PM
Re: Another Turbo 305 TPI question!
Nevermind I did some research and this turbo is too small because it won't have enough volume
BlueIroc-Z
Jun 9, 2019 03:22 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
