tuning carb for supercharger
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
I recently installed a b&m 144 supercharger, I have two carbs to use. First one is a edelbrock 1411(750 cfm) and the other are dual side draft Weber carbs (400cfm each).
I'm starting with the edelbrock because it is easier to work with as I have no exp. With Weber. Now I know they are tuned lean from the factory.
Does anyone have any experience with the 144 supercharger?
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: tuning carb for supercharger
Originally Posted by Mrbanados
I have two carbs to use. First one is a edelbrock 1411(750 cfm) and the other are dual side draft Weber carbs (400cfm each)...
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
You have two carbs, or two sets of carbs? Meaning do you have two Edelbrocks and two Webers, or one Edelbrock and one Weber? I will reach out and invite member Flirtin1 to this thread to see if he will chime in and help you because he has a lot of experience with roots blowers...
Car: 83Z28 HO
Transmission: G Force 5 speed
Can you even put dual Webers on a 144?!? Even if you can, I'd go with the single 750cfm. I tried an Edelbrock carb with my blower, and it made good power...but you'll need to do some adjusting. After it's all said and done, I stuck with a DP carb. But you'll need to boost reference the power valve for it to work correctly. Damon got around the referencing by using a 10.5" or so PV to a non referenced carb. You just need to experiment a bit.... Damon has a lot of experience with the Weiand blowers.
Just don't run it too lean while you're in boost, and get a boost retard. Should be fine then.
Billy Decker
Sep 4, 2015 03:46 PM
GeneralIesrussi
Sep 3, 2015 03:23 AM
