support bracket for 600b procharger?
Old Jul 6, 2014 | 01:33 PM
chevyredneck8's Avatar
Car: 88 Iroc Z
Engine: L98 350
Transmission: 700 R4
I purchased the support bracket from procharger that was suppose to be able to hook up after drilling a couple holes but I don't think it going to work even after grinding I think I can only get one bolt. I can see how it would work on other models does any have an support bracket mounted or custom made one for a 600b?
Old Jul 6, 2014 | 01:37 PM
Car: 88 Iroc Z
Engine: L98 350
Re: support bracket for 600b procharger?
Here's a pic it wont fit between the tensioner and the support bolt
Attached Thumbnails support bracket for 600b procharger?-wp_20140706_14_23_39_pro.jpg
Old Jul 7, 2014 | 06:37 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
i would grind down the alum spacer alittle and grind the bracket down some to see if you could squeeze it in there or could you move the hole over alittle towards the other hole on the stiffening bracket?
Old Jul 8, 2014 | 07:12 PM
92Z's Avatar
92Z
I believe that support bracket was designed for the "SC" series of blowers.
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
Briandrex
Oct 5, 2015 06:20 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
Twinn Engines
Sep 25, 2015 06:27 AM
