newb considering building a turbo car
Old Jul 10, 2014 | 01:52 AM
supper89''s Avatar
Car: 1989 rs camaro
Axle/Gears: 4.11
so i bought a 89' camaro for a pro street car, im starting with a 89 thats mostly stock. the 305 in it has a bottom end knocking... so i want to build a turbo 350, heres what im starting with
-sbc 350
-9.3:1 comp.
-OEM vortec heads
-comp cs xe262h-10 cam, intake .462 exhuast .469
-performer rpm air gap intake
-edelbrock 1406, 600 cfm carb
.....this is the turbo kit im thinking about, http://www.ebay.ca/itm/SBC-SMALL-BLO...-/201106684075
how would this setup work? and what would i need to change to make it work? im looing for about 500 hp, is that possible?
Old Jul 10, 2014 | 07:24 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: newb considering building a turbo car
Should work fine.
Old Jul 10, 2014 | 07:30 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Is the UserID supposed to be super, or supper? Kinda feeling hungry now lol...
500-HP will be easy with a 350, it would be harder not to make that much...
Old Jul 10, 2014 | 07:37 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Only thing i am not sure about is air fuel distribution on dual plane intakes when used for blow thru aps. Most go single plane but that may hurt driveability some
Also that header may need some mods to fit. See Anesthes' thread, single turbo L98 parts list and his build thread
Old Jul 10, 2014 | 07:47 AM
Here's a good article using a dual plane intake, a la Ken Crocie...
http://www.carcraft.com/techarticles...iac_400_build/
Old Jul 10, 2014 | 10:27 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
-sbc 350
-9.3:1 comp.
-OEM vortec heads
Check out this sticky:
Important/Useful : Stock L98 Non A/C Single turbo parts list
anesthes
He used that header and possibly that turbo.
It should make your HP goal.
Do you already know how to modify that 1406 carb for boost?
You need a boost referenced fuel pump too.
Old Jul 10, 2014 | 02:20 PM
supper89''s Avatar
Car: 1989 rs camaro
Axle/Gears: 4.11
Well it was supposed to be super... Haha that's embarrassing
Old Jul 10, 2014 | 02:24 PM
supper89''s Avatar
Car: 1989 rs camaro
Axle/Gears: 4.11
I did some research on blow thru carbs.. It seems to be a fairly complicated to make my 1406 a blow thru, would I be better off upgrading my carb? And I read about single plane intakes as well, but I'm gonna attempt my performer rpm first and I can always swap it out, what torque converter should I run with this set up?
Old Jul 10, 2014 | 02:28 PM
Reach out to Administration, they will fix it for you...
- Rob
Terrell351
Jun 13, 2021 01:13 PM
Reborn756
Sep 4, 2015 03:42 AM
jharrison5
Aug 19, 2015 05:53 PM
makaveli09
Aug 12, 2015 09:07 PM
