procharger question
Car: 92 firebird gta
Engine: L98 with minor mods.
procharger question
What would be a safe boost level for a 92 gta L98? I will use whatever size intercooler system it would need to run safe. The motor is stock but in very good running shape. Last question is what kind of gain could I hope for with a pro charger kit?
Car: 88 GTA, 74 T/A
Engine: 383 stroker (Procharged)
Transmission: TH400 w/brake (new 2013)
Axle/Gears: 12-Bolt S60 - 3.73 (new 2013)
Re: procharger question
This is straight off of prochargers site. Those boost levels they list are for modified engines. I would say a safe level is somewhere between 5-8 psi on a bone stock motor. Others may have different opinions. The higher the boost you run the better chance for detonation.
http://www.procharger.com/GM/gm_auto.shtml
1988-92 Camaro / Firebird DescriptionHP GainIntercooler
9,12 psi w/ P-1SC 60-80%2 Core
15-20 psi w/ D-1 or D-1SC 85%+3 Core
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
If you have at least a full exhaust on the car the 4" pulley on a D1SC will give you 10 psi at 5500 rpm which I thought was safe. This will lower your times by a second, add some slicks and you could be in the 12's. Oh and you might want to up your injectors to 30 lbs at least and I would recommend learning how to program your own proms to get the most out of it.
Car: 88 IROC-Z
Engine: GEN 4 LY6 (going forged 408)
Transmission: 60E (going RPM LEVEL 6 4L80E)
Axle/Gears: 7.5" 3.42 (staying...)
Car: 89 GTA
