TPI intake bottom plugs and holes in runners question
Old Mar 4, 2015 | 02:03 AM
jimw67's Avatar
Engine: TPI 327 SBC Turbo MS2
Transmission: 200-4R CKP Stage 2
I'm putting together a TPI to use with a turbo. I'm using a set of Profiler heads. I mention the Profiler heads as they do not use an exhaust crossover. My question is about the small holes in each lower intake runner that appear to be for the EGR system and/or cold start system. Do I need to plug those holes to keep from putting boost into the valley due to the intake's exhaust crossover is partially exposed to the valley due to head design? If yes, can the plugs on the bottom of the intake (with 14mm allen socket) be removed easily to access? Does installing an EGR delete plate eliminate access to these holes?
Thanks in advance - Jim
Old Mar 4, 2015 | 02:52 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: TPI intake bottom plugs and holes in runners question
Those holes do not lead into the valley. If you remove the heat shield from the bottom of the lower intake manifold that faces the oil valley, you will see that it is all plugged up underneath. The holes in the runners only lead to the EGR crossover to recirculate exhaust gases from, boost pressure will only force it back towards the cylinder head, not the oil valley...
Old Mar 4, 2015 | 05:07 PM
jimw67's Avatar
Thanks. So if I'm running an EGR valve block off, then I should no issue. Sounds great.
Old Mar 4, 2015 | 10:00 PM
No issue at all. Remember to disable the EGR in the tune...
Old Mar 5, 2015 | 03:03 PM
jimw67's Avatar
No EGR to disable - running a Megasquirt. Thanks again for the help.
1992rs/ss
Jan 31, 2025 05:10 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
