Finished the drivers side turbo header
Old Dec 18, 2001 | 09:30 AM
Guido's Avatar
Car: 2000 Trans Am
Have a look see!
It clears the steering column, has lots of plug and plug wire clearance, and also lifts out from the top. I have to do some tweeking on making the pipes match at some of the joints, but overall its not bad. I should be able to have it %100 prepped for TIG this week sometime.
Ill start on the passenger side next week when my next batch of tubing arrives.
Old Dec 18, 2001 | 11:23 AM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
Looking good
Steve
Old Dec 18, 2001 | 11:25 AM
Arianboy's Avatar
Looks good! I've been watching the board and reading a lot of your posts lately. Just trying to get some good info on what it'd take for a turbo upgrade.
I was wondering why you've got the #1 exhaust tube turned up so high? It would seem easier to just bend it down into the collector. They don't appear to be "equal length". I'm guessing that isn't so important on a turbo car, but then again I really don't have any idea if that's important or not! Or if they really are equal length at that.
Keep the good stuff comming, I'm learning a lot more than I'd expected.
Thanks,
Old Dec 18, 2001 | 01:03 PM
Guido's Avatar
Car: 2000 Trans Am
It would have been nice to turn it down but it wouldnt make the sharp radius I needed with the bends i have available to turn it down so I turned it up.
Old Dec 18, 2001 | 08:29 PM
89ProchargedROC's Avatar
Guido just wants to be cool and have things looking weird so he has an excuse to talk to people at the track
Old Dec 20, 2001 | 12:52 AM
GMI FAST's Avatar
Get that damned thing together, Curt!
Old Dec 20, 2001 | 03:30 AM
SteveSpohn's Avatar
Looks good Guido. How are you gonna tack weld everything together with all the tape over the joints? Not trying to be smart Won't everything move when you remove the tape from the joints, or did you keep the actual seam untaped?
Steve
Old Dec 20, 2001 | 06:17 AM
Guido's Avatar
Car: 2000 Trans Am
I put a mark at every joint so I know how the pieces assemble. Im in the process now of going back and tacking all the joints and it is going together pretty smoothly.
Old Dec 20, 2001 | 10:12 PM
Guido's Avatar
Car: 2000 Trans Am
Well you wondered how it would look welded. Here it is tacked up.
The front tube needs some massaging to merge into the collector but get that one sunk and I will be ready to TIG.
Old Dec 21, 2001 | 03:26 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Guido, Who are you getting the Stainless tubing from? I'm using buttweld sched 40 els for my project, Later I may upgrade to a complete stainless setup. Thanks, Bob
Old Dec 21, 2001 | 03:48 PM
Guido's Avatar
Car: 2000 Trans Am
Burns Stainless
www.burnsstainless.com
Old Dec 21, 2001 | 10:30 PM
Bobalos's Avatar
How the heck are you going to weld the two stubs between #3 & #5? did you buy the flange that had the stubs sticking out of it & then build on that? I thought that would be the best way to get a flange that is less likely to leak.
B (just bought a Hobart for some welding fun) W
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Mutillator
Oct 1, 2015 06:05 PM
Street Lethal
Aug 14, 2015 08:25 PM
timonator
Aug 11, 2015 09:56 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
