Turbo on a budget: 91 Z28 rear mount build
#151
1 Post
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Re: Turbo on a budget: 91 Z28 rear mount build
Ah, That makes sense to now with the timing. Earlier I said I was surprised it would handle that much timing, but now I see why because the bin vs dizzy base was off by 5+8 = 13 degrees so your 23 degrees total was really 10 degrees.
I agree with the need of IAT cooling above 10psi. Not a bad night at the track, just a few little things to sort out.
#152
I still had fun. Gotta find out the issues at the track since my butt dyno dont work on cars like this
After fixing timing, it does still seem to do ok with my timing table. I'm seeing some pulled at downshift but it tapers away over time during the pull. Possibly too much down low so i pulled 2-3 deg between 2400-3600
The meth is helping some too even with 50:50 mix
#153
I always see retard at the shift on $59 with the stock knock sensor, tapers off just like you described then shows back up on the next shift. I pulled almost all of the timing out and it still did it so I assume it's picking up some other mechanical noise
#155
Well car still feels slow. Gutted cat and it didnt help anything if in fact made spool alittle slower. Air fuel was dialed in from mid 12's to mid 11's and no big change
Going to look into the distributor and plug wires. I think it was arcing before so likely getting weak ignition so perhaps not all cylinders are firing? We shall see.
#156
1 Post
Engine: 3xx ci tubo
The small cam 305ci is just kind of a turd. Look at the specs on that A4 cam.
At 10 PSI, I would expect 200*((10+14.7)/14.7) = 340 crank hp.
It needs a cam minimum. Something in the 204 to 212 duration range.
#157
It should have the L98 cam but feeling how this car runs i am beginning to question that. All my research says all 91-92 305 tpi cars got the L98 cam
Regardless i dont think its blowing out spark or lack of spark energy. I replaced wires with my old 8mm set and car felt alittle better but hard to say. It runs clean thru boost but just doesnt have the ***** i thought it would assuming 175-180 whp stock from some dyno threads here i seen.
Figured 300 whp on 10-12 psi? That should run low 13's at 108 with this crap 2.1 60 ft
#158
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
I have a 212-218 .500ish 110 cam for sale. Stick that in there!!
#160
Car: 1991 RS
Engine: 5.0
#162
That's what I have heard too. If you do pull the cam and measure it could you post the results here? From what I've heard there were no peanut cam's in the '91-'92 LB9's. Power differences were supposed to be in the exhaust difference between the N10 dual cat cars vs. the single cat cars. It would be cool to get a definitive answer on this without asking all the guys with LB9's to pull the cam out and measure them lol.
#164
Car: 1991 RS
Engine: 5.0
From here.
List every year Camaro and options. It says for that car and that year with auto was 195 hp. 5 spd would have been 230 hp. I haven't searched elsewhere and I'm not preaching it as the gospel, just the info I have.
The Tech. Data section on here has is listed as this:
91 Z28 M5,A4 LB9 V8 9.3:1 5.0 (305) 205@4200 285@3200 TPI.
#166
Car: 88 Iroc. 12.60@ 107. 1.72 60'
Engine: 350 paxton sn93 36lbs injectors
Axle/Gears: 9in. 390s
Any updates or more track time slips?
#167
Nope. Been daily driving. Waiting to buy another wideband for it. Gotta tighten plug gap then i can test it.
Refocusing on my black car now. Weather is cooler now so going to start running that car this weekend.
Looking into rebuilding my spare 305 and making that swap next spring or over winter with a bigger cam. We shall see. It also needs a torque converter lol
#168
Ahh i see. yeah i can imagine why you would want to worry about the black car. Pennsylvania racing weather is about to start.You think shell have some more in her with the weather coming? Mabey pick up 3-5 tenths? id love to see a low 8 run.
#170
Hence the thread name turbo on a budget haha. i did alot of reading through google and other websites, i never found a real good complete answer on the rear mounts. but there are deffinetly some cars out there putting some serious numbers down just like front mounts...Yellow bullet .com has alot of info on anything.
#171
Its not popular since front mounts are easier to do if you arent concerned with keeping car stock looking or dont need emissions or ac and all that stuff
But they work fine. My car spools decent and makes boost just doesnt make power yet and its likely due to a few little things like ignition, plug gap, an old motor, mild cam, etc.
I'll be upgrading this over time. Hope to see some respectable times before end of year
#173
I gotta find time to get back into this car. Still gotta regap plugs and see what happened to my oil pump. Drove in rain and relay fried because i didnt install an fuse on the power supply. I forgot
So rewired but battery is dead so charged up last night. Hope to see if it all works again and i hope i didnt mess up the oil pump.
#174
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 3:90
I just read through all of this. Awesome job. I also see you're from Pittsburgh. I'm from around there as well. Latrobe. I was wondering if you plan on taking this bad boy to any meets next season coming. I'd love to see it in person and maybe get some pointers for my t/a.
#176
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 3:90
#178
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 3:90
#179
Went 13.47 at 110 mph first pass on 10 psi boost. Ran a few more 13.49-13.59 runs but would not go faster than that on more boost. Gotta figure out why lol my guess ignition. Needs a converter and ignition box my guess
#180
Fyi another good oil pump to try that is half the cost is tilton 40-527. Hearing some good reviews on it
I am swapping to a .68 ar turbine housing instead of the .96 thats on it now in hopes to make it alittle more fun and responsive on street. Lack of torque converter and no exhaust wrap makes it alittle laggy unless you get a wot downshift. So i have .68 housings from my last build laying around i'll try first. That way i dont spend 30$ in wrap to try improve heat retention
Trying to borrow a msd 6a box to see if ignition improves. All goes well and weather stays nice may try to race again this weekend
#184
Well put the .68 housing on, cleaned up dizzy cap, and installed msd 6al box.
Made no difference so not sure whats up.
Slip on right was 11 psi. Slip on left was 20! Lol no difference really. Maybe blowing thru converter but trans shifted fine. 5100 rpm drop to 3800 ish. Twice. So if it was converter i thought it be alot higher rpm.
Oh well. Also had some coolant drip out of the heater core onto the passenger foot well carpet so thats not good lol may be pressurizing the system. Tired old 305
#185
Car: 86' IROC
Engine: Supercharged 350
Axle/Gears: 3.45
If you use a ratcheting philips bit you can have that bitch out in 20 min. And thats weird Would have thought atleast your 60 foot would have atleast picked up a little
#186
Summit sent me the wrong distributor cap but i doubt it will solve my problems. I thought maybe cap was bad since it shocked me when setting timing, on stock plug wires. Figured wires were bad. New wires didnt seem to change how car ran but i didnt test for arcing around cap again
May try a hotter than stock coil but i figured the msd 6al would have overcame the stock ignition power and should have seen better results. No dice so far.
I dont think converter cuz i had shifts and blowing thru should act like its flatlining rpm. Or showing little drop on shifts. Does seem to show near 10% slip on top end tho
Only thing else is valve float. Perhaps it cant hold valves shut but its only a 5000 rpm motor lol seems strange to me if it was valve float. Rpm pull was alittle unsmooth however
Now i gotta decide if i should dump money into more igntion stuff, converter and possibly rebuild heads to pick up the power.....or look into a 4.8 swap haha
#187
1 Post
Engine: 3xx ci tubo
Looks like 11 psi is right on the money with the ET: 5.825*[(195*.85)/3600)^(1/3)] = 13.49 sec
I would have stuck with the .96 A/R housing. Especially if going higher than 12 PSI.
The thing holding it back is the cam and exhaust pressure. Put a 208 to 218 duration cam in it and the bigger housing on it and get into the low 12s.
That 305 ain't that tired.
#188
5100 is where it shifts. I dont think 4800 would have made any difference
I also dont think cam is a problem as all my research seems to show 91-92's got the L98 cam. Boost should make power but clearly does not and doesnt respond to ignition. I dont think exhaust pressure is that bad but i would have to measure. Car does get blowby and now cooling system is getting pressurized. I am thinking valvesprings.
Its much more responsive with the small housing tho on street which is more fun
If i get a converter i'll go back to the .96. But now i gotta decide if i am gonna tear it down/rebuild my spare motor, or cut my losses and go 4.8. I can get one for same price as machine work to clean the block and heads. Actually cheaper. Rebuild 305 likely will need decked and bored. New pistons. Not sure its worth it.
I got to upgrade a good bit of stuff on the other car to try for a 7.99 next yr. not sure what i will do
Probably need to refresh the motor, and def upgrade valvesprings
#190
1 Post
Engine: 3xx ci tubo
Maybe it does have the bigger cam. What is the tach yellow/red line rpms?
Pressure in coolant system would lead me to think blown head gasket.
I would go with the 4.8 if you are considering it as an option. Best bang for the buck. The 305 is fun to play with but not worth putting any money into. Rebuild heads for one........nah, go 4.8.
If ya go in to upgrade springs, might as well measure the lift.
#191
Its blowing coolant out of the heater core under boost now lol
I wont do springs with heads on car. Bare minimum i'll have to do head gaskets and clean up the heads, install a mild cam. Thats all i think i will do.
4.8 or 5.3 i will want to remain rear mount but need to maintain ac system. Will have to look into that
Already have hp tuners and a harness to integrate into stock system. Should be easy swap. Only problem is ac system, not sure how it all goes together in a stock thirdgen system. Good thing its already Converted to r134
#200
Car: LT4 C4, LT1 CE, 95' Dyno Air
Transmission: ZF S6-40, 4L60E, sprockets
Axle/Gears: 3.45, 3.07
It's not bad. I would just buy a new one though; only $30.
