Nitrous solenoid bracket miniram
Car: 88 Trans Am GTA
Axle/Gears: 12 bolt 3.73
Going to throw the bottle on the car. I have a miniram3 on it and would like to use the nitrous outlet lt1 noid bracket. I don't know if the bolt holes are located in the same spot on those intakes. So, I figured I would see what you other miniram guys are doing/using.
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Re: Nitrous solenoid bracket miniram
What does that bracket look like? Take a pic and post it up. I had the nitrous works bracket and later switched to a combo of NX and nos solenoids on a nos bracket. I mounted the solenoids on the shock tower to keep them out of the way. Wherever you can put them they will work.
