Concealed nitrous kit
Car: 1992 Camaro z28
Transmission: Automatic
Axle/Gears: Stock
Can the Edelbrock concealed nitrous kit be slightly upgraded. It comes with a 12 oz bottle can I use the 1.3 lb. bottle and can I re jet the kit to 40 hp since it is only rated to 30 lb. I just want to make minor changes to the kit. Any ideas
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Re: Concealed nitrous kit
This is a pretty old thread. i cant see using a 1.3lb bottle being very useful for a SBC. Maybe a motorcycle. I only got roughly 3-4 passes on a 125 shot out of a 10lb bottle. Spraying 30-40 shot in my opinion is pretty useless for the amount of work and safety equipment needed.
Jay
Jay
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
Jay
Jay
Transmission: A4
I had a concealed wet kit on a 97 WS6 back in the day. I hid the solenoids, fuel pressure safety switch, RPM window switch and purge inside a gutted factory battery which was mounted in the stock location. The fuel and nitrous lines were hidden with wire loom and run inside the air intake. THe real battery was mounted in the back and the bottle was where the spare tire used to go. I had a remote bottle opener and warmer on it as well. No one had any idea I was spraying 150hp!!!!
