Random questions about upgrades
Old Feb 16, 2017 | 11:02 AM
kleetis's Avatar
Car: 88 Camaro z28
I was wondering if someone were planing on putting a supercharger on a engine a little bit down the road. what are some parts that NEED to get upgraded so a engine could run properly and net blow up like valves and fuel stuff. What should be upgradedone first to make it safe I guess. Thanks
Old Feb 19, 2017 | 02:04 PM
toronto formula's Avatar
Car: 89 Firebird Formula
Engine: 383 tpi vortec heads Xr 269 cam
Re: Random questions about upgrades
Start with basic tune up items plugs, wires, fuel filter, air filter, distributor and rotor, etc
you should be able to run low boost up to 6-7 psi without too many issues.
i ran the above with water meth injection and everything else stock
it ran ok
Old Feb 20, 2017 | 10:36 AM
86CamaroDan's Avatar
Car: 86' IROC
Engine: Supercharged 350
Axle/Gears: 3.45
Your fuel system is gonna need to be rock solid. Bigger injectors, boost refrenced fuel pressure regulator, a way to tune it, a larger pump at the minimum and some sort of way to retard the ignition timing when in boost
