twin T3 / T04E 57-trims on 305 driveable?
Old Jun 14, 2017 | 09:11 AM
Jeremy85's Avatar
Car: '85 Camaro
Engine: LG4
Transmission: 4L80E
Axle/Gears: 3.42:1
As the title suggests, if I did order the Ebay stainless headers with T3 flanges, then a pair of turbos with T3 hot sides and 57-trim T04E compressors, is a 305 likely to spool them up before uselessly high RPM?
Heads are 416s, considering a mild cam like a Crane Energizer 260/260.
Thanks!
Old Jun 15, 2017 | 07:00 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Re: twin T3 / T04E 57-trims on 305 driveable?
I once ran a similiar combo. Stock 305 TPI and then put a small cam in it like the 260/260 and had the ebay T4/T3 57 trims on it. It spooled fine for the street. It would make boost around 2500-2800 rpm. The only problem was that at cruise rpm and a light load it would compressor surge at 0-5 PSI.
The twin compressors equate to a 76mm compressor single. The exhaust turbines are too small for that size compressor. I ran the T4/T3 because they were cheap but I didn't run them long. I ditched them for a single 70mm turbo.
Old Jun 15, 2017 | 08:06 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I wanted to run those turbos on my car. I cant see them being laggy at all. I ended up doin a larger single t70 and it spooled fast on the rear mount.
Those should be 50.5 mm comp and a 55/65 turbine. Seems like a decent match imo
Old Jun 15, 2017 | 12:43 PM
junkcltr's Avatar
Engine: 3xx ci tubo
The 50.5mm comp wheels would be better. The ebay "57 trim T4/T3" I had were 54mm comp wheel inducer.
Old Jun 15, 2017 | 02:48 PM
83 Crossfire TA's Avatar
Was this the stock LB9 car?
What T70 was it?
I keep debating what to put on my LT1 headed 305... but that will be mounted in the engine bay, I'm worried that everything I have sitting around will be too small or too big...
That was my reaction as soon as I read that. In general, it should be fun, but might get old just cruising and it going into boost all the time.
Old Jun 15, 2017 | 06:09 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Yes my now sold lb9 car. On3 70 mm T4
Old Jun 16, 2017 | 09:11 AM
junkcltr's Avatar
Engine: 3xx ci tubo
The 305 TPI I have with baby cam has an engine mount stock exh manifolds GT4296 T6-1.28 A/R and 3.5" out exhaust. Spools at 2300 when going WOT and good on the top end. Your LT1 head 305 would do fine with even a 76mm compressor.
