turbo recommendations 02 LQ9 6.0
Old Sep 6, 2017 | 03:26 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
what turbo would you guys recommend for a 02 6.0 LQ9 motor? the compression is high so i would think low boost...
Old Sep 9, 2017 | 06:52 PM
Z28FAST1's Avatar
Re: turbo recommendations 02 LQ9 6.0
China 78/75 is the best bang for buck.
Otherwise pt76/75
Old Sep 18, 2017 | 09:16 PM
zya5point0's Avatar
Car: 87 IROC
Transmission: auto
Please post a build thread when you do it. I wanna put a 6.0 with a turbo in the wife's avalanche, so I'm always looking for actual results
Old Sep 19, 2017 | 10:31 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
The 78/75 sounds good. Anything close to a Garrett GT4202 spec.
Old Oct 5, 2017 | 06:58 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
S400 is also good. Depends on power goals but the 7875 and 7675 type stuff make good power. 600-700 whp
