nos on tbi
Old Jan 5, 2002 | 10:46 AM
bad@ss89camaro's Avatar
Car: 91 Z/28 convertible
nos on tbi
can i put nos on my stock 92 camaro rs tbi 305 will it blow my engine if not then what shot would be safe to use
Attached Thumbnails nos on tbi-front-veiw-my-car
Old Jan 5, 2002 | 01:33 PM
88IROCZJG's Avatar
Car: 1988 IROC-Z
Engine: stock L03
Transmission: auto
There is a NOS kit for your car. It's the only one I have seen for the TBI. I don't know if any others can be made to fit or not. It's $550 dollars and adjustable from a 75-125 shot. On a stock 305 TBI most guys say don't go over a 100 shot just to be safe. Your not the first person to ask this question.
Old Jan 5, 2002 | 05:01 PM
NJ SPEEDER's Avatar
there are a few guys that i have seen running 125shots on completely stock 305 tbi's. with a few mods there was one guy running very low 13(like 13.1's). as long as it si a wet system(it sprays the nitrous and fuel in together, like a plate system usually does) it is not as bad a shock to the bottom end of the motor and you can get away with a huge squeeze. i know at least 2 LT1 guys running 150shots on stock motors with wet systems.
later
tim
Old Jan 5, 2002 | 09:49 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I have installed and like this system: http://www.bgfuel.com/nitrousworks/frames/GM/GM_TBI.htm also I think this system has potential in a TBI car given the jets are changed to a TBI fuel pressure friendly set; http://www.holley.com/HiOctn/ProdLin...densystem.html the new top shot system.
Old Jan 6, 2002 | 01:18 AM
TBI305Camaro's Avatar
i was considering getting that kit but my car has 101k miles on it...would it still be safe to run a 75 shot or maybe a tad more? and would a 75hp shot be worth having? im about to put a TBI edlebrock manifold on it including the mods in my sig...what you all think?
Old Jan 6, 2002 | 01:26 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
dont for get the TB swap from holley (670 CFM) and the possibility for a 350 swap (with the right cam and maybe 350 chip) I think 75 would be fine also check out http://www.outlawperformance.com/gmtbiall50hp.html
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
