6.0L S400 front mount set up??
Old May 22, 2018 | 12:00 AM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Hey guys I'm looking for pics anyone might have of their front mount s400 framed T6 turbo. Did you have to move the radiator forward at all?? How involved was it routing the piping?? Easier to work with a tubular k member?? Any ideas you guys might have throw them my way my time to get this underway has finally arrived. Thanks guys
Old May 29, 2018 | 09:13 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 6.0L S400 front mount set up??
Tube k is definitely a positive lol. Frees up some weight and leaves alot of room.
Makes it easier to build exhaust side and access plugs etc
Depending if you run downpipe under motor or not. If you go out the fenders which i dont like then guess it dont matter
Probably can squeeze the turbo inbetween motor and rad. Depending what accessories you run. I thought i seen pics on instagram or fb groups but dont have any on hand.
Old May 29, 2018 | 01:33 PM
thatsupnow's Avatar
I've got the tube k in there and I was planning on moving rad ahead about 2.25" to give it some extra room and the accessory brackets would keep everything tucked in tight just running alternator, water pump and possibly power steering. Still not sure yet. The downpipe is kinda what I'm concerned with don't know if I should go down and under the pass side or just go under the front fender. Hmm decisions decisions
Old May 29, 2018 | 01:42 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Its tight but depending on your header design and if you dont have ac box, you can fit 4” downpipe on pass side firewall
Old May 29, 2018 | 09:06 PM
thatsupnow's Avatar
I'm thinking of using headers like these down and forward ones from xs power. I was looking at the Holley turbo manifold setup but after seeing a guy on ls1tech using them on his 89 bird there's zero room on the passenger side. But up and forward might work out better maybe then the downpipe could just go under the headers and down
Attached Thumbnails 6.0L S400 front mount set up??-screenshot_20180529-200144_ebay.jpg
95Cam86Roc
LSX and LTX Parts
Mar 1, 2015 06:38 PM
bnoble
Jun 7, 2013 10:21 PM
ScottyRock
May 20, 2011 03:26 PM
IROCFAST
Dec 28, 2009 12:24 AM
IROCFAST
South West Region
Oct 14, 2009 07:50 PM
