T6 S400 92 Z28
Old Jan 20, 2010 | 08:35 PM
ScottyRock's Avatar
Car: 92 L98 Z28 Heritage Hard Top
Engine: L98 350 w/ HSR,24lbs inj,AFPR
Transmission: TCI Super Street Fighter W/3300 sta
Axle/Gears: 3.73 Detriot NoSpin,LPW cover
T6 S400 92 Z28
Got to build the foundation first.
Power is nothing without Control
Old Jan 20, 2010 | 10:12 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Re: T6 S400 92 Z28
That is a heavy cast piece off a DD engine. Good luck finding flanges to fit and seal properly. I think only the factory cast pieces that butt to it will work and make a good seal. You probably don't want to hear this, but I you are better off making your own merge section because of the angles the two pipes will enter the T6 flange.
Old Jan 21, 2010 | 08:40 PM
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Re: T6 S400 92 Z28
comming from someone with a T6 based turbo in a third gen, your not gonna like your mounting options! or you can buy my old t6 header/crossover if ya wanna make life easier :P I have it in the FS section
Jay
Old Feb 14, 2010 | 11:11 AM
ScottyRock's Avatar
Re: T6 S400 92 Z28
The build is going slow. Working on the Holley Stealth Ram intake, 58mm TB, and log headers to T6 cast merge. Doing my turbo set up like Bnoble.
Old Mar 21, 2010 | 11:15 AM
ScottyRock's Avatar
Re: T6 S400 92 Z28
got my HSR finished last night, I hope today I will be driving my baby around NoVa...
Old Jun 18, 2010 | 04:38 PM
ScottyRock's Avatar
Re: T6 S400 92 Z28
Car runs very good N/a with 24LBS injectors, HSR intake, Accel remote coil. Ran a 7.80 in the 1/8th in the other day with my old 26-11.50-16 MT ET Streets, I hope it runs a little faster with my new rubber and rims. Turbo set up is going oh so slow, getting ready to order my turbo and some related parts from Majestic Turbo in Texas.
Old Jun 19, 2010 | 02:32 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Re: T6 S400 92 Z28
What turbo are you putting on it?
Old Jun 21, 2010 | 11:59 AM
Jay_rich's Avatar
Car: 1987 Z28
Re: T6 S400 92 Z28
Title says S400
Jay
Old Jun 21, 2010 | 12:06 PM
ScottyRock's Avatar
Re: T6 S400 92 Z28
S400 Turbo from Majestic Turbo out of Dallas Texas,
Old Jun 21, 2010 | 12:32 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Re: T6 S400 92 Z28
Originally Posted by Jay_rich
Title says S400
Jay
Lots of flavors of the S400. It is like saying I am putting a V8 engine in it. I will take a guess at it being the standard DD S400.
Old Jun 21, 2010 | 12:46 PM
ScottyRock's Avatar
Re: T6 S400 92 Z28
71mm 1.32 AR T6 S400 Turbo
Old Jun 21, 2010 | 10:29 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Re: T6 S400 92 Z28
I just looked at turbodaves.com and the S400 with 75mm CW, T6-1.32 A/R turbine is listed for $629 w/ free shipping. It seems like a better deal than the site you posted. You might want to check at theturboforums and see if other vendors have a better deal.
I think the 75mm CW would be better than the 71mm CW for your setup.
Old Jun 22, 2010 | 05:25 PM
ScottyRock's Avatar
Re: T6 S400 92 Z28
sweet thanks
Old Jun 23, 2010 | 02:09 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Re: T6 S400 92 Z28
I'd take off the front rims and run skinnies the next time you take it to the track, may yield some good gains.
Old Jun 24, 2010 | 03:02 PM
ScottyRock's Avatar
Re: T6 S400 92 Z28
I just over inflate the fronts to MAX PSI, that works for me
Old Jun 25, 2010 | 08:46 PM
83 Crossfire TA's Avatar
Re: T6 S400 92 Z28
heh... max... I usually shoot for 55-60, though I wouldn't recommend it to anyone.
Old Jun 28, 2010 | 09:15 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Re: T6 S400 92 Z28
You guys might want to run the numbers for rolling resistant vs air resistant. The rolling resistant is small is general at 35 PSI. The air resistant swamps the rolling for most of the run. I think you would gain more by putting a plate under the car vs. changing wheels.
Over-inflating is just dangerous. Maybe a hundreds gain in ET.
Old Jun 28, 2010 | 05:19 PM
Re: T6 S400 92 Z28
Forget running the numbers, I know what I gain with 245/60-16, 235/60-15 and 215/65-15, I've got time slips.
Funny, going from 245/50-16 to the 215's at 50-60psi I get better gains than most people get by going to skinnies at normal pressures, and I've got a set of 15" firebird wheels that almost match my 16" "high tech" firebird wheels. Heck, I get more of an increase adding the extra pressure to the 245's than I do by going to the 215's at stock pressure, and the 215's/firebird wheels are 23lbs lighter than the 245's/TA wheels.
Old Jun 28, 2010 | 09:49 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Re: T6 S400 92 Z28
Well I am curious. What are the gains in ET with just higher air pressure?
Old Jun 28, 2010 | 11:22 PM
Re: T6 S400 92 Z28
On my near stock formula 350 I went from 13.7199@97.8 to 13.6075@99.9869 with no changes besides swapping stock front wheels for the 15's with 215's on them (both in the 50-60psi range). I need to find one of my older timeslip logs to find exact numbers on the pressure change thing, but I know that going from somewhere around 28-32 to 50-60psi with either 245/50/16's or 235/60/15's I saw almost exactly the same improvement as changing wheels.
Old Sep 10, 2010 | 11:10 AM
ScottyRock's Avatar
Re: T6 S400 92 Z28
Old Sep 10, 2010 | 04:16 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Re: T6 S400 92 Z28
You did a nice job fitting that T6 in there.
Old Sep 27, 2010 | 05:35 PM
ScottyRock's Avatar
Re: T6 S400 92 Z28
HAHAHA you so funny, still working on it on the engine stand, going very slow the economy sucks.
Old Feb 5, 2011 | 09:18 PM
ScottyRock's Avatar
Re: T6 S400 92 Z28
Well I have a wish list, and am waiting on my tax return and I am finally start ordering the big stuff, like turbo, WG, BOV, FPR, and inter cooler, oh and a lock right locker for my rear end
Old Mar 14, 2011 | 10:08 PM
ScottyRock's Avatar
Re: T6 S400 92 Z28
Well got taxes, paid some bills, and soon a turbo
Old Mar 16, 2011 | 09:16 PM
ScottyRock's Avatar
Re: T6 S400 92 Z28
Just ordered SPOHN LCA'S, LPW Ultimate rear cover and axle brace kit
Old Mar 17, 2011 | 01:41 PM
ScottyRock's Avatar
Re: T6 S400 92 Z28
Just spent $950 at Summit Racing, on rear end parts. Building the foundation for my project
Old Mar 19, 2011 | 04:48 PM
ScottyRock's Avatar
Re: T6 S400 92 Z28
Parts are in. Now I am waiting on my order from LPW and LCA's from TGO clasifided
Old Mar 19, 2011 | 05:02 PM
ScottyRock's Avatar
Re: T6 S400 92 Z28
This is no joke
Old Mar 20, 2011 | 02:55 PM
ScottyRock's Avatar
Re: T6 S400 92 Z28
Summit sent me the wrong axles, now my day is shot
Old Mar 20, 2011 | 03:27 PM
scamaro355's Avatar
Car: 92 rs
Engine: 355 stealth ram, dart heads, S480
Transmission: 4L80E
Re: T6 S400 92 Z28
ok so what rear and tranny are you gonna try to run... im hoping you ditched the 10 bolt
Old Mar 20, 2011 | 04:03 PM
ScottyRock's Avatar
Re: T6 S400 92 Z28
No I am keeping the 10 bolt, doing the "ULTIMATE" 10 bolt build, I have a TCI street frighter 700r4 with a 3300 stall,
Old Mar 20, 2011 | 04:55 PM
scamaro355's Avatar
Car: 92 rs
Transmission: 4L80E
Re: T6 S400 92 Z28
ok so what kinda power numbers are you shooting for?
Old Mar 23, 2011 | 08:32 PM
ScottyRock's Avatar
Re: T6 S400 92 Z28
Its a stock headed, stock bottom end, with the HSR, 24lbs injectors, Accell coil, and a "Hot Cam", should be about 200ish to the wheels. I got the right axles now I just have to get time to work on it. LCA's came in also
Old Mar 23, 2011 | 08:56 PM
ScottyRock's Avatar
Re: T6 S400 92 Z28
The correct axles
Detroit NOSPIN LOCKER
Old Mar 25, 2011 | 03:58 PM
ScottyRock's Avatar
Re: T6 S400 92 Z28
So hopefully I can drive my car this weekend!?!?!?!?
Old Mar 31, 2011 | 04:56 PM
ScottyRock's Avatar
Re: T6 S400 92 Z28
More toys
Old Mar 31, 2011 | 07:12 PM
ScottyRock's Avatar
Re: T6 S400 92 Z28
Nice
Old Mar 31, 2011 | 07:40 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: T6 S400 92 Z28
I broke 5 ten bolts including one "ultimate" 10 bolt buildup. Personally that money would have been better spent purchasing a used 9" setup from a local racer. No getting around the small ring and pinion on them.
Old Apr 1, 2011 | 02:47 PM
ScottyRock's Avatar
Re: Turbo L98 Heritage hardtop
It just has to last to last till next tax season, then I will get the 9" rear and the rest of the turbo parts to finish my car in 2012, well 2012 is my target to have my car finished.
Old Apr 1, 2011 | 02:55 PM
ScottyRock's Avatar
Re: T6 S400 92 Z28
I have been spending a lot of time on theturboforum.com and am thinking I am going to go with a Gt45 turbo, with a 1.05 a/r, found some really inexpensive one's on the web site, and lots of really good turbo tech
Old Apr 1, 2011 | 03:50 PM
  #42
project89's Avatar
Re: T6 S400 92 Z28
ebay gt45 u wont be disapointed
theres something like a 14 page long thread on them on ttf.com
Old Apr 1, 2011 | 04:20 PM
  #43
ScottyRock's Avatar
Re: T6 S400 92 Z28
Yea
Old Apr 1, 2011 | 04:21 PM
  #44
ScottyRock's Avatar
Re: Turbo L98 Heritage Hardtop
That's exactly why I changed my mind on turbo selection, TTF.com is the $h!T for turbo info, turbooptions.com is ok, love TGO
Old Apr 3, 2011 | 10:30 AM
  #45
ScottyRock's Avatar
Re: T6 S400 92 Z28
Gear mesh
Old Apr 4, 2011 | 09:53 AM
  #46
junkcltr's Avatar
Engine: 3xx ci tubo
Re: T6 S400 92 Z28
This thread is over a year old and still has nothing to do with a power adder? When are you installing that bad boy? Gear mesh pics......trans & rear-end forum? What ebay seller did you get the China GT45 from?
Old Apr 4, 2011 | 11:28 AM
  #47
ScottyRock's Avatar
Re: T6 S400 92 Z28
Pal-performance is who I am getting my turbo from.
Got to build the foundation first, and it's going to be turbo charged as soon as the foundation for the project has been finalized. Can't build a house on a grassy knoll, got to lay the foundation first, I am going to do this right the first time, why change 2 or 3 times, it's cheaper to just do it right the first time. I have been hear since 2003 and have watched as people build nasty F-body's with 100% stock suspensions and wonder why the can't HOOK or are braking parts all the time
Old Apr 4, 2011 | 02:48 PM
  #48
junkcltr's Avatar
Engine: 3xx ci tubo
Re: T6 S400 92 Z28
C'mon, you know how we build around here. Start making power and fix broken parts as you go! That GT45 should put a smile on your face.
Old Apr 4, 2011 | 09:35 PM
  #49
ScottyRock's Avatar
Re: T6 S400 92 Z28
Just got to get a Tq-arm and new shocks and struts and then the turbo set up is next on the list, I have a plan laid out and am sticking to it, unlike my last car, my 87 IROC T-top, I learned alot, and am putting lessons learned into this car.
Old Apr 4, 2011 | 09:41 PM
  #50
junkcltr's Avatar
Engine: 3xx ci tubo
Re: T6 S400 92 Z28
If you need any pictures or measurements of the GT45 before you get it just let me know.
