Question about a non functioning turbo , non-thirdgen.
Old Jan 6, 2002 | 12:50 PM
AFRO IROC Z's Avatar
My friend's sister has a nissan 300zx twin turbo. She took it to a mechanic to have some work done and he said the turbo isn' t functioning. My friend drove the car and said when he hits the throttle the boost guage starts to go up to like one or two psi and then just drops to zero. What can cause a turbo to not make any boost. My guess would be the waste gate being stuck open, or the blow off valve. I don't know a whole lot about turbos but i learn pretty fast so if someone could give me some ideas, i can go and research, if it is needed and maybe help a dansel in distress. Thanks in advance.
Old Jan 6, 2002 | 02:58 PM
TheCamel's Avatar
The best option is to talk to thed boys on
http://www.twinturbo.net
This is a 300ZX specific Forum
The 300ZX is a finicky car and with the Balance tube, it is highly possible for what you are saying to be true. The system has safety boost solenoids to keep the engine safe if there is a problem. So if there is excessive knock or a problem detected from the ECU it will limit the system to 6psi of boost. 6 Psi from one small turbo would quickly be devoured by the 3.0 liters of displacement of the engine.
TC
colton_carlson
Mar 8, 2019 12:21 PM
fasteddi
Sep 2, 2015 10:29 AM
PestilenceIV
Aug 20, 2015 03:32 PM
redmaroz
Aug 16, 2015 11:40 PM
mustangman65_79
Aug 11, 2015 03:17 PM
