what compression ratio with NOS?
Old Jan 7, 2002 | 03:53 AM
Joseph Andres's Avatar
Car: 1991 GTA Convertible
Im planning to install AFR 190 cc aluminum heads. Will 10.5 : 1 be too much for a 150 shot of NOS?
Old Jan 7, 2002 | 07:48 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
How much compression you can run wether with NOS
or not depends on the octane of the gas you use.
If you can only get 92 octane gas I'd go for 9.5:1 cr with iron heads and 10.0:1 with alumium. If you can get 94 octane gas you
should be ok but no more. Make sure you don't over advance the timing, and run a plug a little cooler than stock. Should be 32 to 36 deg total. When first testing the Nos, retard the timing about 4-5 deg and check the plugs for detonation. Be sure that you are suppyling enough fuel at the designed pressure for the NOS.
I would strongly suggest mixing some 110-114 octane
race gas in the tank 30-50% for your first tests. The cost and bother is minor compared to rebuilding the motor 'cause you broke a ring land (detonation). Forget octane booster....
Old Jan 9, 2002 | 12:27 AM
BTW how would you go about reading plugs for detonation?? What would they look like if they are or not?
Old Jan 9, 2002 | 06:04 AM
F-BIRD'88's Avatar
Search my posts I,ve done an extensive speul on the subject.
InfernalVortex
Apr 20, 2021 11:31 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
FormulasOnly
Jul 23, 2018 08:47 AM
Vincent135
Sep 28, 2015 10:50 PM
Damon
Sep 26, 2015 04:29 PM
