Turbo Experts...Non-Thirdgen...Homemade boost controller??
Old Jan 12, 2002 | 10:45 AM
CamaroX84's Avatar
Well, I started driving my winter car - 1989 Dodge Daytona 2.5L Turbo 5-speed. This guy at my work had a turbo Talon, and he made a homemade boost controller using plumbing parts from Ace Hardware. He said he would make one for mine, but he went off to college and I don't have his number. I was wondering if anybody knows where I can find a tech article or something so I can do this myself. I'm not sure what it consists of, but I'm pretty sure you hook it up to the wastegate so that you can achieve a higher pressure than stock. Any ideas? Any help would be greatly appreciated. Thanks.
Old Jan 12, 2002 | 11:07 AM
Guido's Avatar
Car: 2000 Trans Am
It basically consists of two barbed pipe fittings screwed together. Inside of this assmelby, you place a spring and a ball bearing. You can tailer it to what boost reference you want your wastegate to read by turning the amount of space the spring can move in.
If you go to www.google.com and do a search for manual boost controllers, there are plenty of DIY tech article out there on how its been done.
Good luck.
Old Jan 13, 2002 | 01:37 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
the ones I've seen look exactly like this but without the water separator and gauge. It is an regular air regulator and ive even seen them routed to the drivers compartment for adjustment on the go while looking at the boost gauge for exact settings. For scale perposes that is 3/8" hose barbed on this one but you can get like some 7/32" hose barbs to fit it and use it with re-enforced vacuum/emmisions hose.
Attached Thumbnails Turbo Experts...Non-Thirdgen...Homemade boost controller??-mvc-001s.jpg
Old Jan 13, 2002 | 10:46 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
This is a buddy of mine maybe this is what your looking for?
http://www.joepmbc.com/
dont mind the site. Im getting ready to redo it.
Old Jan 14, 2002 | 10:27 AM
a73camaro's Avatar
Goto this site. TONS of great info.
Turbo info!
Your looking for a Grainger valve
There is the problem with the computer cutting out with overboost. The site deals with that also.
Read, read, read!
Hotrodboba400
Dec 10, 2019 07:07 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
