Whats a good cam to use with n2o?
Old Jan 13, 2002 | 04:54 PM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
Transmission: TH700-R4
I'm looking for a good cam that will work good N/A and also with a 150 shot of n2o? The engine I'm building has an edlebrock intake,SLP runners,ported plenum for induction. I was thinking of using Crane Cam #104224 214 220/.452 .465/112. Any opinions?
Old Jan 13, 2002 | 07:37 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I am also interested. Is there something I'm missing, that doesn't seem like much lift on that cam .452 .465. I got a ZZ4-3 cam in now. I was planning on going larger, is this going to be a prob. w/ my Nitrous Xpress lit? Thanks.
Old Jan 13, 2002 | 10:20 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
Z28z I like that profile for a couple of reasons. It probably wont screw you speed density (map sensor) efi system up, secondly it is not too big to prevent good cylinder pressures for good nitrous power (good small sized blower cam too). and lastly instead of going with a 114 or even 113 lobe cam which could produce too high of cyl pressures (under rarer circumstances) you went with the 112 lobe, good job.
Old Jan 14, 2002 | 11:30 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
B4C - do you think I'll be ok w/ the cam I have? When I swap the cam out what would you recommend?
Old Jan 14, 2002 | 05:25 PM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
Old Jan 14, 2002 | 10:26 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Re: Whats a good cam to use with n2o?
Z28z,
That's the cam that I'm getting put in my 305 (I know your a 350)which will be getting a supercharger at the end of the year. I would say this this is a good cam for a blower/nitrous application. Also, this is the cam that Willie uses to run 12s in his blown 305.
Robert
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
junkcltr
Aug 2, 2019 11:12 PM
camaro71633
Sep 1, 2015 10:24 AM
cstrobel65
Aug 15, 2015 10:19 AM
TreDeClaw
Aug 14, 2015 06:58 PM
