Splitting stock fuel line.
Old Jan 14, 2002 | 01:32 PM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
When installing another fuel line for nitrous use, do I have to make a custom fuel line using "AN" fittings and adapters or can I tap into the steel line with rubber fuel hose and clamps. I know the stock fuel pressure on my tbi camaro is 9-13psi but, can I get away with this or should I make my own using the "AN" fittings. I want to do it right but I don't want to waste any money if I don't need to. Thanks
Old Jan 14, 2002 | 02:39 PM
89ProchargedROC's Avatar
how much do you plan on spraying?
you shouldn't need an extra fuel line for the spray until you are really getting into some high n2o shots and then it can be an "option"
Old Jan 14, 2002 | 10:07 PM
GKK's Avatar
GKK
I'm starting with a 100 shot. I'm going to get the "NOS" TBI system for my tbi Camaro RS. I think it's a Wet system and needs a separate fuel line along with the Nitrous line. Does anyone have this system?
Old Jan 15, 2002 | 07:02 PM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
If you are buying a complete kit for your application, then it should have the necissary fittings and hose to tap into the fuel system included in the kit.
Old Jan 15, 2002 | 09:15 PM
GKK's Avatar
GKK
Great, I'm gonna get the TBI Kit from "NOS" I think the part number is 5153. I didn't think the kit would be so complete.
Old Jan 18, 2002 | 04:07 PM
EddieDellz's Avatar
Im haveing the problem of tapping into my fuel lines and its not a any ideas of what i could do .. i tryed the fittings i had and it was too small .. im trying to run a 100 shot any ideas?
Old Jan 18, 2002 | 05:27 PM
IROCKZ4me's Avatar
You could cut the hard line and use rubber hose and clamps with a T or Y hose barb fitting, or if you wanted to do it a more "professional" way, cut and flair the hard line, and use tube nuts and sleaves (or use hard line adapters) to splice in an AN style T or Y fitting, and use and AN hose end and hose off of that to fuel solenoid.
Grant2k
Jul 10, 2018 04:01 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
theshackle
Mar 5, 2017 06:37 PM
italiano67
Dec 11, 2016 09:21 AM
NBrehm
Aug 25, 2015 11:49 PM
