Vortech Kit for MAF converted to MAP, recirculation question
Old Sep 9, 2020 | 01:48 PM
KyleF's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
As the title states, my 88 MAF has been converted over to MAP with EBL. I am planning a nice silicon hose intake to replace the MAF and associated dryer hose that came with the kit. I understand for MAF why once the air passes the MAF you don't want to release it. Hence recirculation over BOV vent to atmosphere. Can the recirculation valve be vented to atmosphere?
Old Sep 9, 2020 | 10:41 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Vortech Kit for MAF converted to MAP, recirculation question
Yes you can vent to atmosphere. Most of us do.
When I had a TPI kit back in the 90's, I used rigid 3.5" aluminum to my air cleaner rather than the hvac duct that vortech supplied.
-- Joe
Old Sep 10, 2020 | 10:38 AM
KyleF's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
-- Joe
going the Silicon route for mine. Just wanted to double check if I needed to tie the recirculation valve back in.
Old Sep 14, 2020 | 07:20 AM
KyleF's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
Surprisingly enough, this caused the VE to move, in some cells as much as 3%. I can see from a previous log that my MAT temps dropped. I didn't think the system would be so sensitive.
TheExaminer
Dec 13, 2015 11:25 AM
sweden
Jun 13, 2015 12:37 PM
luvofjah
Apr 12, 2015 01:49 PM
dharrison
Apr 1, 2004 08:03 PM
TRAXION
Sep 9, 2003 09:53 AM
