Any ideas what kind of power it'll make??
Old Jun 26, 2023 | 01:39 PM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Hey guys figured ask y'all what you think my set up could make?? My hand got split in half at work a few days ago so I'm just getting a little bored, so humor me
91 Camaro z28
Iron block forged 370
BTR Trinity intake
LSA cylinder heads, stainless valves, Trickflow spring kit
Comp cams 233*/235* .619"/.621" lift int/exh 116* LSA
Holley Dominator ECU
Holley 120# injectors
Icon 102mm TB
Dual 340 pumps -8an/-6an PTFE feed/return lines
Dual feed to front of rails
Racetronix regulator
94 chevron(no ethanol) pump gas mixed to 105
Built 4l80e with Jake's lvl3 rebuild and recalibration kit
Circle D 258mm pro series single disc converter
VS racing billet 80mm T6 turbo
Vs racing 50mm wastegate with dome pressure sensor
7# gate spring with 8# of dome pressure
Dual Mac solenoid boost control
A2A 3" intercooler
MWC fab 9" 3.25 rear gear
275/40-17 Mickey Thompson Street et drag radials
So I did get the bugs worked out before I headed out to work and have been hitting 15-16 psi. I was doing runs and logging things as I went along. I'm also at 13 degrees timing at WOT.
Just curious what it could potentially make as is, I can't really do much as I'm a bit of a gibble right meow.
Thanks everybody
Attached Thumbnails Any ideas what kind of power it'll make??-pxl_20230410_194823872.jpg
Old Jun 26, 2023 | 03:28 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Any ideas what kind of power it'll make??
You're probably over the 600 at the wheels mark. I am sure once it is fully tuned and broken in, you'll get a lot more.
Old Jun 26, 2023 | 03:44 PM
thatsupnow's Avatar
Sounds like an alright start. Once I can get it on the rollers and tuned I'd like to see close to 900 whp
Old Jun 26, 2023 | 03:53 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I wouldn't see how that is out of the question. It's a pretty heavy build.
DNSTA
May 20, 2017 11:15 AM
martindforsythe
Apr 3, 2016 03:29 PM
xpndbl3
Sep 13, 2007 09:29 PM
NastyL98_T/A
Carburetors
May 31, 2005 09:25 PM
rsilver
May 19, 2003 09:51 PM
