Pinning and bogging under boost.
Subscribe
Jul 26, 2023 | 07:42 PM
Hi I have a 86 Camaro with a 2.8l 5 speed. I put on a small Rotorex C30 supercharger, it has a bog and it pings under boost, it goes up to about 10 psi at higher rpms. I have a water intercooler, 17lbs injectors from Southbay, second fuel pump, 8:1 FMU. it is worse in first and second gear. I turned the timing down but that did not help. I was thinking of adding a MSD with boost retard. The engine is all stock with headers, and a JET chip. Any help would be appreciated.
Reply 0
Jul 31, 2023 | 10:52 PM
Re: Pinning and bogging under boost.
Quote: Hi I have a 86 Camaro with a 2.8l 5 speed. I put on a small Rotorex C30 supercharger, it has a bog and it pings under boost, it goes up to about 10 psi at higher rpms. I have a water intercooler, 17lbs injectors from Southbay, second fuel pump, 8:1 FMU. it is worse in first and second gear. I turned the timing down but that did not help. I was thinking of adding a MSD with boost retard. The engine is all stock with headers, and a JET chip. Any help would be appreciated.
What fuel are you using?? Is this combo tuned for everything?? Have you data logged anything??
Reply 0
Aug 1, 2023 | 09:24 AM
I am running premium gas. I am running a stock computer, no data logger.
Reply 0
Aug 1, 2023 | 09:39 AM
Quote: I am running premium gas. I am running a stock computer, no data logger.
Premium gas as in 93 octane?? Either way I'd suggest you take it to the rollers and get it sorted out that way
Reply 0
Aug 4, 2023 | 08:37 AM
Quote: Any help would be appreciated.
You need a wideband reading, a solid datalog, and better timing control...
Otherwise you're shooting your arrows during the night at a target you cannot even see...
dynamicefi.com
- Rob
Reply 0
Aug 4, 2023 | 09:39 AM
I got the pinning sorted out with a timing adjustment, But it still bucks under boost. I closed up the gap on the plugs to .032, and replaced the cap and rotor. The wires are fairly new.
Reply 0
Aug 19, 2023 | 05:47 PM
I got the bogging sorted out. I got a set of 20lbs injectors from South Bay Fuel injectors that seemed to do the trick. No more bucking and it has way more power.
Reply 0
Subscribe
