NOS on 305 Questions
Old Jan 23, 2002 | 12:13 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
hey guys i bought a used 88 305 LB9 motor a while back it had nos on it and i dont know what jets they were using, the motor had 68k miles on it, i recently had the motor rebuilt, it had a few slightly bent rods in it a spun rod bearing and 2 cracked oil rings and the cylinders were worn pretty good, what would cause that at 68k miles? i had it rebuilt because of the burning oil in 2 cylinders, question is, would it be safe to use 100hp shot on it without damage like that ? and at least go 80k?
i'm using stock cast pistons, stock crank turned .10
Old Jan 23, 2002 | 12:30 AM
RSRagtop's Avatar
Somethin' wasn't right with that system. If I remember right, that kind of damage is the result of pre-ignition, like whoever was running it didn't retard the timing when they were juicing the motor. If your rebuilding with stock cast pistons, go easy on the squeeze, like no more than 100 or 125 max.
Old Jan 24, 2002 | 06:36 PM
camaro6spd's Avatar
I thought hyper where the stock pistons.....
69 Six Pack
Oct 5, 2015 07:51 PM
fasteddi
Sep 2, 2015 10:29 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
