point me in the right direction
I think I've decided to put some more money into my project, but I was wondering if someone could help me out with the basics. I want to supercharge, probably with the ATI w/ intercooler, and I want to put it on the 383 TPI I'm building up. Can someone tell me where a good learning reference is? I've got questions like does a supercharger work with speed density? What computer changes will I have to make? How much exhaust do I need? And what about cams? Will a second job cover the cost or do I need a third? Even though I hope to make a monster, I want to try and keep it a streetable sleeper. Thanks a lot.
Car: 85 iroc,96 z28,96 Ram 2500,69RR
Engine: 383 with AFR heads.
Transmission: richmond 5 speed
Axle/Gears: 1991 w/1LE.auburn pro series.2.73's
a good start is right here use the search engine on this site, but probably skip the t-shirt board and throw out some 2 word or 1 even on the subject. -boost, detonation, compression, p600b, d1sc, you get the picture there is a freakin huge info base here-and it helped me do on my car just what you are planning on yours. lurk around and ck.it out and understand some info is meant to be ignored too-thats up to you. but if you hang long enough you will see that there are some really dialed in people who know the ways and most will assist freely. but its up to you to do some homework yourself, first. seeya frank
:rockon: srv
:rockon: srv
Hill1513
Sep 19, 2015 04:15 PM
