turbo near the muffler?
hey guys,
how close does the turbo need to be to the engine, is the closer the better, or if I do a set up can I move it over by the y-pipe or maybe put it where the cat is now. I would love to have a turbo car that you can't see the turbo on. whats the secret
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
serious ground clearance issues and probably some increased turbo lag from being farther away from the engine. A turbo's intake and exhaust are perpendicular to each other. Intake routing and oil/cooling lines etc. would be interesting as well.
Might work with some increasing of the hump already there though.
Car: Old Car - 1982 Vette. New Car - 1972 Vette Convertible
Engine: Old Car - 1200hp TTSBC 427. New Car - TT LS7X
Transmission: Old Car - 4L80E. New Car - TBD
Turbo's are dependant on exhaust energy (heat), and the further you move them away fromt he exhaust valve, the less efficient and effective they are. It's always a good idea to keep pre-turbo plumbing to a practical minimum.
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
The biggest problem with mounting a turbo low is the oil return. It must be a thick free flowing downslope back into the oil pan above oil level. It is very important that the oil drains easily from the turbo.
It is possible to drain the oil to some type of extra oil tank below the turbo. Then a dry sump oil pump can pump the oil back into the engine oil pan ...
The Callaway Sledgehammer Corvette used a system like that.
Car: 1991 Camaro Z28
Engine: L98 5.7 350 TPI
Transmission: Brand New (again) 700r4
Axle/Gears: GM 10 bolt 7.625 W/ TrueTrac 3.23
Re: turbo near the muffler?
This stuff is ancient!!!! If only they knew that remote mount turbos would be something that not only works, but is pretty cool....
Transmission: 5-speed/T-5
Holy talk about going back in time, Batman.
6 years!
6 years!
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
It still isn't because most engine bays have enough room for turbo(s). The energy calcs show where it should be for optimal performance. A lot of people just want good enough.......and in comes the RMT setup. Although, it would be interesting to try a RMT with thick wall SS pipe.
