Need Help! Fluid dampener yes no?
Old Feb 27, 2002 | 07:16 AM
moore82nd's Avatar
i have a supercharged 350 400-500hp and im going to be running it up to 6000 rpm do i have to buy a fluid dampener in order to keep my crank from going out or can i get away with stock because im on a tight budget
Old Feb 27, 2002 | 09:22 AM
Monty's Avatar
Car: Old Car - 1982 Vette. New Car - 1972 Vette Convertible
Engine: Old Car - 1200hp TTSBC 427. New Car - TT LS7X
Transmission: Old Car - 4L80E. New Car - TBD
No, at an rpm limit of 6000 or less, a good stock type damper is fine. BHJ makes a good stock style damper that is not much more than an OEM damper.
If you were to go with an aftemarket damper, I recommend an ATI Superdamper over the Fluidamper. Having said that though, if it's just a street application (where SFI certification is not needed) and rpms are kept around 6000 and below, the Streetdamper is a pretty good deal at around $150.
Old Feb 27, 2002 | 10:15 AM
moore82nd's Avatar
thank you so much for the info where would i find a bhj dampener?
Old Feb 27, 2002 | 10:36 AM
Monty's Avatar
Any good high-performance machine shop or speed shop can get them for you, or probably already stocks them.
HoosierinWA
Oct 7, 2015 10:15 AM
wanext
Oct 6, 2015 12:18 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
mfp189
Sep 27, 2015 09:25 AM
